91 teg ... fuse box question about wires
ok i got this interior lighting that has the cig adaptor, which wires do i wrap about which fuse to make it work ??? anyone know ?
Thanks
Thanks
If you need power for something, your under dash fuse box has "free pins" on it you can use, just above the fuses you will find 4 - 5 free pin terminals, there is a constant and acc. 12V (+) a 2nd ign., [hot when ign. switch is in the run position] and a park light free pin, [hot when lights are on]. The ground wire you can connect to a ground bolt behind kick panel around fuse box.
94
94
There is no "fuse pin" they are free pins, [a male "disconnect" terminal] and you would use a female disconnect, like this... http://www.scosche.com/scosche...0-100
or this... http://www.scosche.com/scosche...0-100
or even uninsulated ones like this... http://www.scosche.com/scosche...5-100 crimped to the pos. (+) wire and then just plugged in to the free pin you want to use.
For the ground lead use one of these... http://www.scosche.com/scosche...8-100
94
94
nerdish
Aug 9, 2001 03:13 PM
