1990 Honda Prelude 2.1 litre
Old Feb 18, 2006 | 11:16 AM
josh351's Avatar
Default 1990 Honda Prelude 2.1 litre
Does anyone have a diagram on how to put a timing belt on a 1990 2.1litre Honda Prelude.....Thanks josh351
Old Feb 18, 2006 | 05:59 PM
90ludeb21a1's Avatar
Default Re: 1990 Honda Prelude 2.1 litre (josh351)
i had to replace the timing belt on my 2.1 and as far as i can remember all you need to do is take the cover off, put pins in the cams, and swap the belts. there may be more to it but it was a long time ago that i had to do this. it isn't a diagram but hopefully it helps.
Old Feb 18, 2006 | 06:00 PM
if the cruise control gets in your way, just loosen the two bolts and move it temporarily. don't worry about disconnecting the cables.
Old Feb 18, 2006 | 10:28 PM
OLDskool91Si's Avatar
Its the same as any DOHC honda engine. Just look up any engine...the procedure is all the same for the most part. Im about to have to replace mine as well....ive changed them a few times on my hondas....REPLACE THE WATER PUMP WHILE YOURE AT IT!! It shouldnt take you more than an 1.5. Good Luck!
tony_2018
Jul 20, 2014 02:59 PM
maflover2
Feb 27, 2008 07:40 PM
imadigitalgod
13
Jun 13, 2006 02:10 PM
gti303
Dec 5, 2005 10:40 AM
beeroh
Nov 23, 2004 08:42 PM
