headlight not working
Old Feb 18, 2006 | 11:12 AM
iNCREDiBLYSLOW's Avatar
Default headlight not working
my right headlight went out. i moved the wires around a little and it comes back on, but when i turn it off and on again it doesn't. how can i fix that?
Old Feb 18, 2006 | 01:09 PM
P_Adams's Avatar
Default Re: headlight not working (iNCREDiBLYSLOW)
I swear, I'm gonna program this as a macro to one of my hot keys.......
What Year and Model Accord, Please?
P
Old Feb 19, 2006 | 08:50 AM
Default Re: headlight not working (P_Adams)
96 accord lx 2.2
Old Feb 19, 2006 | 09:32 AM
P_Adams's Avatar
Thanks, I just wanted to make sure we weren't speaking of a 3rd gen Accord with the hide-away Headlamps. They have unique Headlamp issues of their own.
It sounds that, barring the possibility of harness damage from a previous accident (or screwed up wiring repair), that the connection to the bulb has corroded and intermittently looses connection.
I assume the wires you were moving were directly behind the offending lamp, right?
IF this is whats happening, you can buy a replacement plug from most COMPETENT auto parts stores, cut off the old one and splice the new one to the harness.
P
Modified by P_Adams at 4:31 AM 2/20/2006
Old Feb 19, 2006 | 12:49 PM
YeuEmMaiMai's Avatar
take your light out and using some fine steel wool clean the connectors. I usualy wrap the steel wool around a chop stick and then rub it up and down the connector's metal part, after that I use a paper clicp to pull the metal up a little so it makes good contact with the bulb's connector.
DrunkInThunder
Oct 12, 2018 11:46 AM
swmario383
Jun 14, 2014 03:58 AM
lilned
Apr 2, 2012 03:50 PM
cmgoods
Jun 25, 2006 09:44 AM
Wknd_Warrior
Jan 6, 2003 08:05 AM
