2000 civic wont start!
Old Feb 18, 2006 | 10:16 AM
gunner6696's Avatar
Default 2000 civic wont start!
I have a 2000 civic dx which i just swapped the head for a vtec one. everything looks like its fine it cranks over and everything, fuel is getting there but the spark plug wires are not sparking, does the distributor need to be adjusted/timed? if so how do i do that? could there be any other problems? i also have nology plug wires which were for a nonvtec motor, does that have anything to do with it? please let me know. thanks
Old Feb 18, 2006 | 10:36 AM
eklum's Avatar
timing off?
Old Feb 18, 2006 | 12:38 PM
gunner6696's Avatar
Default Re: (klum)
I replaced the timing belt so i was wondering maybe if that would be an issue, and i wasnt sure if the distributor rotor has to be set at a certain spot. please let me know thanks.
Old Feb 18, 2006 | 01:36 PM
gunner6696's Avatar
Default Re: (gunner6696)
I was reading up and people are saying maybe to turn the distributor 180 degrees....is that a posibility? its turning over but i have no spark from the dizzy
Old Feb 18, 2006 | 01:54 PM
Civicse's Avatar
umm i don't think you should turn it 180 degrees, get a timing light and see if its off. and check the wires, or just replace them if there old
Old Feb 18, 2006 | 01:56 PM
Civicse's Avatar
Default Re: (Civicse)
changing the timing belt won't fix your ignition timing either. plug wires don't care if your vtec or not.
Old Feb 18, 2006 | 02:06 PM
gunner6696's Avatar
i have nology hotwire which were on there prior to this issue.
Old Feb 18, 2006 | 02:08 PM
gunner6696's Avatar
I also still have the dx ecu in the car, i do have the ex ecu but i was gonna swap that in ounce i wire up the car for vtec. could that be the problem? are the timing of the computers or fuel maps an issue? thanks so far
Old Feb 18, 2006 | 02:09 PM
Civicse's Avatar
well check your ignition timing or have someone else do it. and make sure the wires are sending a spark. when was the last time you gave it a tune up (plugs, wires, rotor etc...)?
Old Feb 18, 2006 | 02:16 PM
Civicse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunner6696 &raquo;</TD></TR><TR><TD CLASS="quote">I also still have the dx ecu in the car, i do have the ex ecu but i was gonna swap that in ounce i wire up the car for vtec. could that be the problem? are the timing of the computers or fuel maps an issue? thanks so far</TD></TR></TABLE>
regardless of ecu it should still start. just won't run very well with the y7. ex ecu will be looking for a knock sensor and different IACV, oh and vtec
Old Feb 18, 2006 | 03:19 PM
gunner6696's Avatar
what is a iacv? where can i get one and is it easy to install?
Can i just replace the current iacv for the dx with this one and have everything sloved?
Modified by gunner6696 at 4:30 PM 2/18/2006
Old Feb 18, 2006 | 03:30 PM
Civicse's Avatar
idle air control valve, you have one. if you also swapped intake maniflods you should have it on there. y7 and y8 iacv's are differnt, ones a 2 wire and ones a 3 wire, i forget which one right now though
Old Feb 18, 2006 | 03:34 PM
Civicse's Avatar
iacv doesn't have anything to do with you plugs not sparking either, i was just saying your dx ecu won't recognize the y8 iacv
Old Feb 18, 2006 | 03:52 PM
gunner6696's Avatar
I know that but im saying i am still using the y7 intake mainfold and everything, do i need to go out and buy a iacv that is made for a vtec? also ill it just swap out for the one in there now or do they bolt up differently? I need to take one problem at a time but i can drive it and start it up using the nonvtec ecu? i just wont have vtec?
Old Feb 18, 2006 | 04:01 PM
Civicse's Avatar
it might not run very well and you have a check engine light on. you mind as well get an ex maifold if you can. i'm not exactly sure about the iacv, so a search, its been done before, i think it requires a slight mod to the wiring harness to make the ex iacv work.
Old Feb 18, 2006 | 04:09 PM
s2kkiller's Avatar
first off, you should check your timing forget about all the other bullshit... make sure the timing marks are right on and that the distributor rotor lines up to number one spark plug wire. then go from there... it should still start up with either ecu VTECH OR NOT... just make sure timing marks all lined up correctly and distributor...let us know what happens.
Old Feb 18, 2006 | 04:10 PM
Civicse's Avatar
https://honda-tech.com/zerothread?id=735196
heres a how to on a y7/y8 mini me. might answer that iacv question
Old Feb 18, 2006 | 04:28 PM
macsmurray's Avatar
Check your VSS/alternator fuse, it may have blown.
Old Feb 18, 2006 | 06:12 PM
gunner6696's Avatar
Default Re: (macsmurray)
i have the alternator, power steering, and ac pump belt currently off. (had to replace the timing belt) will that affect it to start up?
Old Feb 18, 2006 | 06:17 PM
s2kkiller's Avatar
the alternator/powersteering etc... doesn't matter it should still start if you have the timing set right, the alternator fuse if its bad it just won't be charging after it starts, just make sure you got good power to the battery the timing marks are set right (distributor too) all sensors plugged in and crank it away...
Old Feb 18, 2006 | 06:24 PM
J.'s Avatar
J.
Ok. So you aren't getting ANY spark whatsoever? Did you pull a plug out and put it in a wire and ground it to the motor while it was cranking over to find this out? You should still get a spark even if the timing is off I thought. Have you by chance thought about the ignition control module? When they go bad they cause a no spark condition.
Old Feb 18, 2006 | 06:28 PM
s2kkiller's Avatar
Default Re: (J.)
Yeah but think about it the car started before he touched it the odds of that going bad are pretty slim, but possible
Old Feb 19, 2006 | 08:25 AM
gunner6696's Avatar
Default Re: (s2kkiller)
does the distributor have to be set a certain way? what are some good tips one setting the timing perfect?
Old Feb 19, 2006 | 09:24 AM
s2kkiller's Avatar
« Re: (Civicse) « » 5:09 PM 2/18/2006 Reply Edit
make sure the timing marks are right on and the distributor facing number one spark plug (you have to take off the cap for this)
Old Feb 19, 2006 | 11:34 AM
gunner6696's Avatar
Thanks, ill let u guys know.
joeekrub
17
Dec 8, 2022 08:24 PM
mikesp0008
Apr 17, 2018 02:54 PM
90Rexx
Jul 3, 2009 06:23 AM
93LsVx
15
Jun 24, 2009 04:23 AM
D15BHatchbackcivic
Jul 28, 2005 10:15 AM
