What do you think about CTR piston's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Colt Seavers »</TD></TR><TR><TD CLASS="quote">People keep on ranting, and raving that CTR piston's are the ****.
In my opinion their not all that great, what do you guy's think? </TD></TR></TABLE>
What aspect of them? Their compression? The fact that their oem?
Vague question.....not voting
Is that because your using them in your own motor.
You will find that with a lighter piston there will be less
stress on your rods. But in my opinion those pistons
are just to damn heavy.
Good luck with your build.
From: Streets of Sacramento...But now living in So Cal, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 »</TD></TR><TR><TD CLASS="quote">as far as oem pistons go...
p30 and p73 get my
p30 and p73 get my
In my opinion their not all that great, what do you guy's think? </TD></TR></TABLE> i think they give u crazy compression and are heavy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KINGSOL18 »</TD></TR><TR><TD CLASS="quote"> i think they give u crazy compression and are heavy.</TD></TR></TABLE>
not in a b16
I think they are a good piston for someone on a budget build or perhaps someone who wants to use all OEM parts, and for someone not looking to spend a lot on aftermarket pistons.
not in a b16
I'm using p30's in my b16 block, and have a GSR head that's milled 30 thou.
I myself would rather use a smaller dome piston, and take some off the
head, or block to get my desired compression.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Colt Seavers »</TD></TR><TR><TD CLASS="quote">I'm using p30's in my b16 block, and have a GSR head that's milled 30 thou.
head, or block to get my desired compression. </TD></TR></TABLE> it depends what your desired compression is. in a stock b16 theyll give u 11.6:1. check out this thread https://honda-tech.com/zerothread?id=717928
i have a GSR with CTR pistons and Type R cams.. At first i was having problems with the motor pinging.. But after the wide band tuning it runs good. I have raced against b-series motors with bigger cams and 2.0 liters. So far the one i race i beat em.. They'll get little ahead on me 1st and 2nd gear.. but 3rd gear pulls like a champ.. and for some reason when it hits 7k rpm the motor wants to accelerate even more but i have to shift at 8500.. Its a beast 3rd and 4th gear.. Im not saying that i can beat b20s or etc. Just the one i race so far i beat.. But yeah anyway.. CTR pistons are crazy fast after CORRECT tuning.
pr3 head b18c bottomend with pct pistons pulled my pig heavy em1 14.07@99 with a 2.2-60 on 17's on pump with nothing more then a p28 with J's program running it...an-r header and 2.5 inch exhaust along with the sk2 stg2 cams i have here are going in along with me tuning it with crome pro
think ill hit 13's =P
What does it matter what I think? You don't like em? Why is that... cause you popped an engine trying to cut corners and not tuning it before running it? I hate people like you who bad mouth something cause they are so inept as to realize that you HAVE to tune the damn thing first.
Really uneven burning, a lot scoring on the exhaust side of the dome. CTRs are not a good piston, P30 or P73 is much better.
what do you guy think would be the best pistons for b20 vtec with gsr head with all skunk2 pro2 cam, gears, valves, retainers, springs, and intake manifold but with out boring the block or would it even be worth the money with no bore.
There's a company call "top line" that just started making 84 bore type R.
A friend of mine bought some, and his cars rippin. Haven't put it on the
dyno yet, but it should make some good numbers. You should look into
getting a set
Come on Joe you know I'd never run those piston's their junk.
Oh by the way thank's for the fan mail
getting a set
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAisBEST »</TD></TR><TR><TD CLASS="quote">Not a fan at all. Very poor combustion quality.</TD></TR></TABLE>
x2
x2
