time for new brakes!! :)
i searched and cant find any, what im looking for is a slotted and vented rotor for front and rear, not crossdrilled...just slotted and vented, and if possible do any brands make a Bronze caliper? and if not do you recomend painting them? anyways thanks in advance guys!!!
Im not sure what slotted and vented mean. This stuff is just eye candy that dosent significantly help slow you down. Buy good pads, good fluid and some Brembo or Auto Zone blacks and youre more then set for the street.
Front rotors are vented stock, the rear rotors are solid. You're not going to find vented rotors for the rear unless you change the calipers on the rear (the rear rotors are too thin to make them vented). If you're looking for slotted, I'd look at Powerslot. From a performance stand point, blanks are fine. I use Autozone Duralast on the track car, and they work perfectly.
I just got a set of rotors & pads on eBay from speedydynamic . . . Definitely recommended. I got 4 zinc coated blank OPparts rotors for $110 shipped, plus Axxis MM pads for another $80.
His eBay auctions are all cross drilled & slotted, but just e-mail him & tell him you want slotted only & he'll quote you a price.
Brakemotive
Sep 17, 2009 11:48 AM
Nipsey Hussle
Mar 14, 2006 08:51 AM
kevinoneill
22
Feb 21, 2004 08:24 AM
