Check Engine Light after Head Replacement
Old Feb 17, 2006 | 04:42 PM
mcgee*'s Avatar
Cigarette Squad
Default Check Engine Light after Head Replacement
well i did head replacement today since my other one valve seals were bad.. and ect.. well everything runs good except i have check engine light
code is something like 1 long blink then keeps doing the long blink till i turn car off
eh any help would be
Old Feb 17, 2006 | 04:44 PM
Luserkid's Avatar
Default Re: Check Engine Light after Head Replacement (McGeeTM)
10 is you IAT, did you hook that up?
Old Feb 17, 2006 | 05:15 PM
SVOboy's Avatar
Is it solid cel? Something about the ecu/ecu fuse mehbe?
Old Feb 17, 2006 | 05:53 PM
Sliced Beard's Avatar
Default Re: (SVOboy)
you probably did not hook the Intake Air Temperature sensor back up......it should be on the bottom of your intake manifold or on the top just behind teh fuel rail on the right hand side between the #3 and #4 runners or on the #4 runner
depending on which engine you have.
Old Feb 17, 2006 | 06:35 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: (DirtySol)
d15b7 yeah im gunna look see if i did, also i doesnt feel like it has as much pull is it because of this or maybe something different
Old Feb 18, 2006 | 09:49 AM
Default Re: (McGeeTM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by McGeeTM &raquo;</TD></TR><TR><TD CLASS="quote">d15b7........it doesnt feel like it has as much pull is it because of this or maybe something different</TD></TR></TABLE>
I think it is because it is a D15b7.......that is just a guess tho
Old Feb 18, 2006 | 04:44 PM
mcgee*'s Avatar
Cigarette Squad
haha, yeah the IAT sensor was blown, replaced it and works now
Old Feb 18, 2006 | 04:47 PM
CoreyR's Avatar
code 1 is O2 sensor, did you plug it back in?
kaoss_11
Sep 10, 2006 04:14 PM
ph0shizzle
May 13, 2006 08:36 PM
sik26
Mar 19, 2005 08:02 PM
integra_type-r
Dec 14, 2004 04:04 PM
vietthuqstyle
Feb 5, 2004 05:24 PM
