low idle issues
Old Feb 17, 2006 | 12:36 PM
vtecb20coupe's Avatar
B A N N E D
Default low idle issues
ok, i've been having problems with my ej8('98 civic ex) and low idle. and when i mean low, i mean around 250 rpm low. stock is supposed to be 750 rpm. nothing has been touched on the motor itself(d16), it has basic bolt ons.
well, over the past few weeks, i'd say that it's cut off on me two times. it starts right back up but i'd like to get this fixed.
any ideas?
Old Feb 17, 2006 | 02:47 PM
mRs_PaNdA's Avatar
Default Re: low idle issues (vtecb20coupe)
warm up the engine to normal operating temp, unplug the AIC, then engine will start to sputter and may even stall, then you should turn the idle adjustment screw until your rpm gauge reads about 450. Shut the engine off. Plug back the AIC, reset ECU and It should be around 700-800 next time you start it up.
Old Feb 18, 2006 | 08:29 AM
B A N N E D
Default Re: low idle issues (mRs_PaNdA)
i forgot to mention, it only idles low after the car has been driven and you come to a stop at a stoplight, etc. if you start the car and don't take it out of park, it's fine. so, adjusting the idle screw is not going to solve the problem.
Old Feb 18, 2006 | 09:02 AM
95DxSi-R2
Guest
Posts: n/a
i believe the iac gives alittle higher rpms on cold start up?
Old Feb 18, 2006 | 01:49 PM
Brick Top's Avatar
pcv valve might be bad.
clean out your throttle body.
grease built up around the butterfly blocks the air needed to idle.
and u can adjust the butterfly opening too.
Old Feb 18, 2006 | 03:39 PM
amckee's Avatar
Sounds like the IAC is not controlling your idle. I would also unplug the IAC while running with the engine warm and make sure the idle is at 450. If the screw won't effect the idle, it may indeed be a dirty TB. Once set at 450, plug it back in and clear your code. If the idle doesn't raise to 750 then you need to check for voltage to the IAC. If the IAC is getting voltage, then it is probably also carboned up or bad. Saying the idle screw is not the problem because it idles while cold is not neccessarily true because the ECU is in default until the ECT reaches temperature.
Old Feb 18, 2006 | 04:21 PM
spuddo01's Avatar
Default Re: low idle issues (amckee)
i had the same problem it was my iac. those things go all the time on hondas so i had an extra one laying around luckly.
Old Feb 19, 2006 | 02:52 PM
B A N N E D
ok, i'll check out the iac and clean the throttle body again. haven't done that in a few months.
aeon117
Mar 5, 2014 09:21 AM
uti-787014
Jun 11, 2009 02:34 PM
