Help where to get denji headlights? need 2 replace ASAP!
Old Feb 17, 2006 | 02:29 AM
J1A1H's Avatar
Default Help where to get denji headlights? need 2 replace ASAP!
My head lights have just failed my MOT because of no beam pattern and poor output...
I need some new headlights and was originally going to get these:
But now i have decided to go for the denji head lights like these below but I HAVE NO IDEA WHERE TO FIND THEM as i am in the UK... can anyone help:
http://www.denji.com/dj-hd767n.htm
THANKS A LOT EVERYONE!!!
and can people tell me what the qulaity is like because i have heard it is very gd... and has anyone got any pictures of them on the civic?
THANKS
Old Feb 17, 2006 | 04:43 AM
DJ_SaNdOz's Avatar
Default Re: Help where to get denji headlights? need 2 replace ASAP! (J1A1H)
Why not these ones:
http://cgi.ebay.com/ebaymotors...QrdZ1
You can get all of the headlights that you posted on ebay...
This probably belongs in appearance cosmetic BTW...
Old Feb 17, 2006 | 05:20 AM
ABK's Avatar
ABK
Default Re: Help where to get denji headlights? need 2 replace ASAP! (DJ_SaNdOz)
why not stock???
Old Feb 17, 2006 | 05:28 AM
ditsboy's Avatar
Default Re: Help where to get denji headlights? need 2 replace ASAP! (ABK)
stock isn't bright enough i think, do you know if those one pieces are bright and easy to install? i was thinking to install those too like the person who created the post
Old Feb 17, 2006 | 07:04 AM
instrument's Avatar
the lights that dj sandoz linked too are VERY bright, a friend bought them, though i didn't like them i did when i was behind the wheel.
but then again, i find my lights (stock) bright enough for me.
Old Feb 17, 2006 | 07:05 AM
blkhatch92's Avatar
my one peice projectors are dim as hell . . . seriously, my high beams are exactly where my low beams should be. =[
Old Feb 17, 2006 | 08:19 AM
jbs's Avatar
jbs
Aftermarket projector sucks. They uses H3 bulbs which are not bright at all. Even in conjunction with PIAA bulbs, light output still sucked. Unless your using it in order to retro fit an HID projector better invest in better bulb for your stock headlights. Just my .02c
Old Feb 17, 2006 | 08:23 AM
SRCivic97's Avatar
Default Re: Help where to get denji headlights? need 2 replace ASAP! (jbs)
Those are the fugliest lights I have ever seen. Buy stock.
Old Feb 17, 2006 | 09:29 AM
built562's Avatar
Default Re: Help where to get denji headlights? need 2 replace ASAP! (SRCivic97)
there is no way that aftermarket projector headlights are brighter than stock. as stated above they use h3 bulbs which are made for secondary lighting. just get some stock ones with some nice piaa bulbs or silverstars
Old Feb 17, 2006 | 10:06 AM
Relic1's Avatar
the term brighter depends on the person. projectors have a cut off point that a lot of people don't like, so they seem dimmer than stock headlights. But the areas that are lit up are brighter and because the light is more focused.
That is IF you use the wiring harness that comes with the Denji projectors.
The TYC projector's output is a little less, more compatable with stock headlights. Just more concentrated due to the projector cut off.
I run PIAAs with the harness in my Denjis and most people think I have HIDs.
But aiming becomes more critical with projectors... if they are a little low you will over-run the lights, if they are a little high you will be blinding on comming traffic really badly.
Much more so than stock headlights.
Old Feb 17, 2006 | 11:15 AM
JeffBro's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">the term brighter depends on the person. projectors have a cut off point that a lot of people don't like, so they seem dimmer than stock headlights. But the areas that are lit up are brighter and because the light is more focused.
Much more so than stock headlights.</TD></TR></TABLE>
Sounds like they are not worth the hassle. Just get some stock ones and put nice bulbs in them. I have heard that the jdm(STOCK) ones are brighter.
Old Feb 17, 2006 | 11:38 AM
shyboi4u's Avatar
get some tyc one piece. there sae/dot approved. they have decent lighting and they take h1 bulbs...
Old Feb 17, 2006 | 11:56 AM
I3ooS710's Avatar
Default Re: (shyboi4u)
http://www.autodynamic.com
DB1_559's Avatar
ebay got them i forgot what seller but the one piece black housing is super bright my bro in law got some and they are briter than my projector with high perf bulbs
Old Feb 17, 2006 | 12:08 PM
J1A1H's Avatar
Hey Everyonei Found these and they already have a phillips hid retrofit inc projectors etc
http://216.82.69.117/detail.as...C-HID
What do you think? i am looking for a black housing and these are perfect!!! what you all think? and about the price?
Do you think these would preform well?
THANKS for the link!!
Old Feb 17, 2006 | 12:24 PM
SmellySOHC's Avatar
Default Re: (J1A1H)
i like those..should be alot better than the Denjis and stock..not a bad price
Old Feb 17, 2006 | 12:29 PM
EJ6_Hatch's Avatar
Default Re: (J1A1H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J1A1H &raquo;</TD></TR><TR><TD CLASS="quote">Hey Everyonei Found these and they already have a phillips hid retrofit inc projectors etc
THANKS for the link!!</TD></TR></TABLE>
where the hell do you see the words "retrofit" anywhere on that page?
Old Feb 18, 2006 | 12:23 AM
92slowcivic's Avatar
Default Re: ({PBA}Threat)
i have projectors, they suck, they don't look cool. i am trying very hard to go back to stock. i lost my stock lights in a disheartening battle with a deer and thought i would try the projector look via ebay. don't do it, think of the kids...
Old Feb 22, 2006 | 02:55 AM
DB1_559's Avatar
o yea forgot to tell you but the only bad part bout it is when the corner bulbs go out you gotta take the bumper of for just one bulb
jdmisoverrated
Jan 29, 2008 01:40 PM
aln2590
May 29, 2007 04:46 AM
hondajav06
10
Oct 13, 2006 08:27 PM
sleek6mt
Honda S2000
Jun 7, 2006 09:35 AM
CivilizedCiv
15
Jun 6, 2002 05:33 PM
