sohc overheats above 300 RPMs???
lately my sohc has been getting really hot if i take it any higher then 3000 rpm's if i stay below that it runs alittler warm but not bad has this happened to anyone? or does anyone know what might be causing it?
Your thermostat isn't opening.......Or you have a severely pinched coolant line that could explode at any minute
Or you have air in your coolant system like these guys mentioned. The thermostat spring is all mechanical, and you can test it by taking it out and heating it and seeing if it reacts as it is supposed to.
The Crx doesnt ever get hot without problems. If thermostat doesnt wrk maybe someone tried to put in stopleak or something and clogged the radiator up. Try running prestone coolant flush through it and refill with with fresh coolant.
Uncle Ben's
Mar 25, 2010 10:27 AM
