Distributor problem!
Old Mar 27, 2002 | 11:05 AM
g's integ's Avatar
Default Distributor problem!
Need some more help guys. This is the best and reliable forum around. This is somewhat a newbie question.
I'm doing a swap on my '95 LS for b16a head and b18c block. Can I use my distributor from my b18b motor? What's an alternative other than Gs-R dist? B16 DIST? Kinda steep for $250.
Old Mar 27, 2002 | 11:46 AM
b19coupe's Avatar
Default Re: Distributor problem! (g'sinteg)
You are going to need an OBD1 B16 or GSR distributor. A 96 or later distributor has different connectors and won't be plug and play. A b18b distributor won't work because it will hit the VTEC solenoid.
Old Mar 27, 2002 | 12:14 PM
g's integ's Avatar
Default Re: Distributor problem! (b19coupe)
Good looking out! appreciate ur help!
Old Mar 27, 2002 | 12:20 PM
RR98DX's Avatar
a LS dist will work juuusstttt fine!
just cut off the leg that hits the soleniod. i will run one, my frined runs a LS on his B16, and val ran a b20 dist on his vtec head (ran a 12.9 too heheh).
it works just fine and saves you allot of $$
Old Mar 27, 2002 | 01:01 PM
g's integ's Avatar
Default Re: Distributor problem! (95CivicSi)
Thanks a million! Your the shhhhhh**! Can't wait to drop it next week.
jdmdohcek98
Oct 13, 2008 09:56 AM
honda011
Jun 10, 2005 09:03 AM
Bnjmn
Mar 1, 2002 04:03 PM
