Vtec or non-Vtec
Old Feb 16, 2006 | 08:37 PM
watsvtecEK's Avatar
Default Vtec or non-Vtec
should i go lsvtec, b16 head, ge conversion kt, studs, with i/h/e. stock bottom end.
or.
ls motor with crower 403's, minor valvetrain upgrade, with i/im/h/e. and maybe also a p&p.
what do you think would produce more power?
thanks
Old Feb 16, 2006 | 08:51 PM
onepoint6i's Avatar
Default Re: Vtec or non-Vtec (D 2da A9)
ls-v no doubt...
Old Feb 16, 2006 | 09:11 PM
watsvtecEK's Avatar
Default Re: Vtec or non-Vtec (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">ls-v no doubt...</TD></TR></TABLE>
even with the ls pistons?
Old Feb 16, 2006 | 09:21 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D 2da A9 &raquo;</TD></TR><TR><TD CLASS="quote">
even with the ls pistons?</TD></TR></TABLE>
Even with LS pistons. You will not be able to run the bigger cams or go very far with cam timing unless the valve reliefs are enlarged. It might be worthwhile to investigate the cost of installing GSR or ITR pistons while the motor is apart.
Old Feb 16, 2006 | 09:26 PM
KingOfQB's Avatar
Default Re: Vtec or non-Vtec (b19coupe)
i ran stage 1s in ls pistons fine and a friends is on stage 2s where u getting info from?
Old Feb 16, 2006 | 09:30 PM
watsvtecEK's Avatar
Default Re: Vtec or non-Vtec (KingOfQB)
yea, i herd you can run 403's (stage 2) with ls pistons fine, but just to be safe upgrade the valvesprings.
Old Feb 16, 2006 | 09:33 PM
watsvtecEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Even with LS pistons. You will not be able to run the bigger cams or go very far with cam timing unless the valve reliefs are enlarged. It might be worthwhile to investigate the cost of installing GSR or ITR pistons while the motor is apart.</TD></TR></TABLE>
well just swaping out some cams is alot simpler then changeing pistons. not to mention with itr or gsr pistons i would have to shave the rods.
Old Feb 16, 2006 | 09:39 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D 2da A9 &raquo;</TD></TR><TR><TD CLASS="quote">well just swaping out some cams is alot simpler then changeing pistons. </TD></TR></TABLE>
The head has to come off for an LSVTEC, no? Changing pistons is more work, no doubt. It would be worth it, but it's up to each individual as to how far they want to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingOfQB &raquo;</TD></TR><TR><TD CLASS="quote">i ran stage 1s in ls pistons fine and a friends is on stage 2s where u getting info from?</TD></TR></TABLE>
We talking VTEC or non-VTEC cams? Two completely different animals. I would not run Skunk Stage 2's on a stock LS bottom end, but that's just me.
Old Feb 16, 2006 | 09:50 PM
watsvtecEK's Avatar
wo wo wo, hold on...
ok when i said changing out the cams i was talking about puting crower 403's on my ls, not the ls vtec. yes i know how to do a vtec conversion i have been doing reaserch for a while now. I've serched and found some threads about 403 in a LS and it was fine on the bottom end as long as you stayed at or close to the stock redline. the only thing that was recomended was to upgrade valve springs, but thats just to be safe. you can run the 403's with stock.
so basicly my question is will i make more power with some 403's in my ls? or more in the lsvtec? if i stayed nonvtec i could probly afford a chipped ecu. and some more goodies.
Old Feb 16, 2006 | 10:01 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D 2da A9 &raquo;</TD></TR><TR><TD CLASS="quote">should i go lsvtec, b16 head, ge conversion kt, studs, with i/h/e. stock bottom end.
or.
thanks</TD></TR></TABLE>
I was just responding to this line of questioning. And I am partial to VTEC over non.
b18bteg14
Jun 2, 2007 01:14 PM
troubledsol03
Oct 30, 2006 01:18 PM
imskatencrzy
Sep 21, 2006 11:17 AM
2uy
Sep 14, 2005 02:42 PM
Big Dick Bandit
13
Sep 16, 2003 05:28 PM
