b16a build
Old Feb 16, 2006 | 08:05 PM
Briancrxsir's Avatar
Default b16a build
All right need your guys opinion, it has been bugging me... I dunno bout the rest of you, but I am gettin spanked by these turbo neons and it is horrible, right now I am running
crx
b16
hasport shift link, mounts, header, aem hybrid intake, custom exhaust, spoon ecu, bf goodwrench drag radials
I am running bout 14.7 in the qt, which is horrible for this set up...
anyways I was going to go with the D and H head package which consists of a major port and polish, stage 2 cams, high flow valves, dual valve springs, retainers, also 68mi throttle body and ported intake mainfold. I talked to the guy who does the work for them and he said my quarter mile time should consist of 12.8 to 13.4 with this step up.. I dunno just find it hard to believe dont wanna spend all the money and not be in that range.. But what I am askin is for some advice on what to do, or if I should go with this kind of set up...
also here is my timeslip
r/t .005
60 2.372
300 6.431
1/8 9.705
mph 75.52
1000 12.501
1/4 14.791
mph 94. 68
Old Feb 17, 2006 | 11:06 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: b16a build (Briancrxsir)
Your reaction time is bad. Practice and you can get to the low 14's.
If you want to beat turbo neons then you will need both practice and a stronger motor (ls/vtec or turbo).
Old Feb 17, 2006 | 12:20 PM
wicked2night's Avatar
Default Re: b16a build (mar778c)
Reaction time is great! He should do something about his 60' times. With a drag radial you should get sub 2.0s times. Do you have wheel hop or something?
Old Feb 17, 2006 | 01:30 PM
UncleD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">Your reaction time is bad. Practice and you can get to the low 14's.
If you want to beat turbo neons then you will need both practice and a stronger motor (ls/vtec or turbo).</TD></TR></TABLE>
Disregard that entire post right there. CRX's are easy to go fast in, I saw a a guy drive a gutted CRX with a stock B16 open header to a 13.6. A slight build on that B16 with some good cams and header, you'll be 12's no problem. Look at Il Will's motor minus the itb's. If you duplicated that setup, 12.6's I would put a gutted CRX at with a good driver.
Old Feb 17, 2006 | 04:27 PM
Default Re: b16a build (clean rice)
naw no wheel up, just when i jsut to launch is the track sucks so bad that my tires just peel out and i get even worse times.
Old Feb 17, 2006 | 04:38 PM
NJIN BUILDR's Avatar
https://honda-tech.com/zerothread?id=1526682
A little heads up on DH racing.Assuming this is the same D and H you referring to.
Glenn
Old Feb 17, 2006 | 05:35 PM
mar778c's Avatar
Community Builder
LOL
Modified by mar778c at 7:42 PM 2/17/2006
Old Feb 18, 2006 | 08:15 AM
allmotorb20vtec's Avatar
build a gsr set up or even a b20 bottom end.
low tq #'s for too much $$
bertsb18hatch
Aug 13, 2008 11:09 AM
CRX11Z
May 26, 2007 03:35 PM
jdm_ef9_b16
10
Jul 16, 2006 11:18 AM
SomeDude56
10
Jan 23, 2006 08:03 PM
mini-cRx
12
Dec 3, 2001 01:48 PM
