B18C1 vs B16a cam caps
Old Feb 16, 2006 | 04:01 PM
RHDintegXsi's Avatar
Default B18C1 vs B16a cam caps
are they interchangable? im getting a decent deal on a gsr longblock minus cams and cam caps..i know cams are interchangeable are the caps also? it would be a lot easier finding b16 cam caps over gsr ones
Old Feb 16, 2006 | 04:34 PM
Runnerdown's Avatar
Default Re: B18C1 vs B16a cam caps (SINFULintegXsi)
The cap are machined with each head assembled and torqued together. You can get another set of caps, but have them line honed at a machine shop with the right equipment.
Old Feb 16, 2006 | 05:19 PM
Default Re: B18C1 vs B16a cam caps (Runnerdown)
so basically i can reuse a set of b16 cams but ill have to remove the head and take it over to a machine shop so they can bore/hone it out with the new caps?
Old Feb 16, 2006 | 06:23 PM
dinko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINFULintegXsi &raquo;</TD></TR><TR><TD CLASS="quote">so basically i can reuse a set of b16 cams but ill have to remove the head and take it over to a machine shop so they can bore/hone it out with the new caps?
Old Mar 4, 2006 | 02:18 PM
Cvic90's Avatar
It's alot of work. the caps have to be close enough to machine them down and then have them honed. Im having it done right now. it worth buying a complete head and changing it out. Unless you have alot of money in head work or more. I have a type R head, thats the only reason I'm willing to spend the money.
Old Mar 4, 2006 | 08:44 PM
Default Re: B18C1 vs B16a cam caps (Cvic90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cvic90 &raquo;</TD></TR><TR><TD CLASS="quote">It's alot of work. the caps have to be close enough to machine them down and then have them honed. Im having it done right now. it worth buying a complete head and changing it out. Unless you have alot of money in head work or more. I have a type R head, thats the only reason I'm willing to spend the money.</TD></TR></TABLE>
i had the work doen already and just finished putting the motor back together..hopefully it'll hold up..we'll see what happends
dc2much
Jan 10, 2010 06:03 PM
AJxr
Jul 26, 2008 08:53 AM
ThefirstPACT
Mar 19, 2008 12:27 PM
RacerRex
Jan 12, 2006 08:04 AM
freeagent32
12
Jul 13, 2005 03:55 PM
