b18c1 pan gasket
Old Feb 16, 2006 | 03:53 PM
3s0n3's Avatar
Default b18c1 pan gasket
is there any spots on the gastet surface that need gasket goop? it looks like there were 4 spots over the block seams under the stock gasket? also does anyone have the tightening pattern and tourque specs?
Old Feb 16, 2006 | 05:45 PM
3s0n3's Avatar
wow good game..... is anyone there
Old Feb 16, 2006 | 05:53 PM
eda6's Avatar
Default Re: b18c1 pan gasket (ESONE S1)
i have the helms for the 94 gsr and checked for you. It was pretty vague.
i'd try the gasket goop in those 4 spots. Starting from the middle, tighten the bolts in a criss cross pattern to 9 ft.lbs.
Old Feb 16, 2006 | 06:01 PM
3s0n3's Avatar
i know a criss cross pattern will be fine but im kinda a perfectionist. and 9 ft. lbs. sounds about right though. thankx for the responce .... anyone else have a link to a diagram
Brembomaster
Engine Machining & Assembly
Jul 2, 2019 10:40 PM
jdmspoonitr
Nov 27, 2010 11:07 PM
firewalkerr
Feb 13, 2006 05:56 AM
Corporation
Aug 25, 2005 05:20 PM
slow90si
Aug 15, 2002 10:01 PM
