stock motor mounts-how/what do i fill it to make a solid ones??
Old Feb 16, 2006 | 11:14 AM
efboy's Avatar
Default stock motor mounts-how/what do i fill it to make a solid ones??
<U>Fill your two side motor mounts, and get the urathane insert for your rear motor mount ???</U> what does that mean ?
how and what do i use to fill my motor mounts, i m trying to upgrade my stock mounts without spending too much, but to handle the shaking (not vibrate)
the mount on my accord driver side is torn in the inside. so pls help me out so i can get this fix, because i m almost done getting parts to boost the f22b. the mount need to be solid.
Old Feb 16, 2006 | 02:54 PM
discrete's Avatar
I dont know much about this topic, but I'm pretty sure a search will yield plenty of answers.
Old Feb 16, 2006 | 03:03 PM
...esteban's Avatar
Princess
Default Re: (discrete)
go to the parts store and get 3m window weld...its the stuff that secures your windshield to the car...just goo that **** in between mounts (out of the car), and let it harden up...works wonders, my mounts (all of them) are filled and i couldnt be happier
Old Feb 16, 2006 | 03:17 PM
uselesshuman's Avatar
Default Re: (...Lost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ...Lost &raquo;</TD></TR><TR><TD CLASS="quote">go to the parts store and get 3m window weld...its the stuff that secures your windshield to the car...just goo that **** in between mounts (out of the car), and let it harden up...works wonders, my mounts (all of them) are filled and i couldnt be happier</TD></TR></TABLE> i second this i have it on my g20 works great oh and make sure you where gloves that **** will stay on your hands for days dont ask how i know
Old Feb 16, 2006 | 03:46 PM
essex's Avatar
Default Re: (uselesshuman)
From home depot you can get "Bull Dog" Polyurathane (in a tube). It works better than the window sealers
Old Feb 16, 2006 | 04:58 PM
s13_240sx_92's Avatar
Default Re: stock motor mounts-how/what do i fill it to make a solid ones?? (efboy)
There was this two part stuff from McMaster I believe. Try searching and you should find out some good info. I know this topic has been covered before. Good Luck
Edit..
http://forums.vwvortex.com/zerothread?id=1188960
https://honda-tech.com/zerothread?id=1168043
hope that helps
Old Feb 16, 2006 | 06:07 PM
sc4dr's Avatar
Default Re: (essex)
urethane is the way to go...just make sure the mounts are<U> clean</U> before you apply
Old Feb 16, 2006 | 07:45 PM
Propulsion's Avatar
Default Re: (sc4dr)
make sure you get this one, http://us.st11.yimg.com/store1...39803
The one at kragen is a different part number and it never drys
Old Feb 17, 2006 | 09:36 AM
stealthmode62's Avatar
Default Re: (Propulsion)
I've always used the "PL"? uerathane in the black and yellow tube from home depot. I have some friends that used the window weld and the window weld seems to have alot more vibrations than the PL from home depot.
Old Feb 17, 2006 | 11:59 AM
efboy's Avatar
Default Re: (stealthmode62)
thnkx for the help everybody. i just finish cocking -hahaha CAulking them right now
i will post result and pics when that ish drys out, and i ll show u guy what i use on it.
Old Feb 17, 2006 | 03:31 PM
D Jaws II's Avatar
Default Re: (efboy)
The following link is a good write-up about Homemade motor mounts.
http://importnut.net/motormount.htm
If at first you don't succeed...go to the web.
HTH
Donnie
Old Feb 17, 2006 | 03:52 PM
Propulsion's Avatar
Default Re: (D Jaws II)
yep, that's where I learned.
More vibration means the material is stiffer.
aenigmapro
Oct 27, 2010 10:59 AM
Kaspk
17
Jan 19, 2008 06:54 PM
Ls On StErIoDs
Oct 21, 2005 09:39 AM
hotdoggies
10
Mar 7, 2005 07:47 AM
B18PoweredCivic
Jul 18, 2003 12:46 PM
