what are those aftermarket speaker to speaker wire adapter thingys called??
Old Feb 16, 2006 | 10:55 AM
cilvia's Avatar
Default what are those aftermarket speaker to speaker wire adapter thingys called??
these were on my first civic but dont have them anymore...and i wanna kno where to get some...its not a harness, but its used to connect your aftermarket speakers to your speaker wires without wrapping the threads of the speaker wire around the aftermarket speaker +/- inputs...but one end of the adapter thing pinches the speaker wires while the other end just plugs right into the speakers...anyone kno what im talkin bout??
Old Feb 16, 2006 | 04:05 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: what are those aftermarket speaker to speaker wire adapter thingys called?? (cilvia)
maybe a speaker harness? If you would give more details or a clearer picture someone could answer your question right away
Old Feb 16, 2006 | 04:50 PM
B18C_EJ8's Avatar
Um, a female spade terminal???
Or as wrx said, a speaker harness adapter.
Old Feb 16, 2006 | 08:43 PM
suspendedHatch's Avatar
Circuit City in the installer bay not just the road shop inside the store.
Old Feb 16, 2006 | 10:39 PM
cilvia's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Um, a female spade terminal???
Or as wrx said, a speaker harness adapter.</TD></TR></TABLE>
yea the spade terminal connects to the aftermarket speakers, and the other end is like a circle that you pinch the speaker wires...i dont know how else to explain it and i have no pics...anyone else might have an idea??
Old Feb 17, 2006 | 04:00 AM
B18C_EJ8's Avatar
A butt connector?
Old Feb 17, 2006 | 09:28 AM
Spicoli v 3.0's Avatar
he's talking about the connectors that attatch to the speaker wire, and slide over the speaker termianals. I think its the spade thingy
Old Feb 17, 2006 | 10:20 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cilvia &raquo;</TD></TR><TR><TD CLASS="quote">these were on my first civic but dont have them anymore...and i wanna kno where to get some...its not a harness, but its used to connect your aftermarket speakers to your speaker wires without wrapping the threads of the speaker wire around the aftermarket speaker +/- inputs...but one end of the adapter thing pinches the speaker wires while the other end just plugs right into the speakers...anyone kno what im talkin bout?? </TD></TR></TABLE> It's called a "female quick release" or "female disconnect" and it looks like this.... http://www.scosche.com/scosche...0-100
also comes "fully insulated" like this... http://www.scosche.com/scosche...0-100
For most speakers you need a 0.250 for the pos. (+) term. and a 0.110 for the neg. (-). 94
Old Feb 17, 2006 | 10:43 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">For most speakers you need a 0.250 for the pos. (+) term. and a 0.110 for the neg. (-)</TD></TR></TABLE>
Wow... I just call them the big ones and little ones...
Or just use two big ones because I'm too lazy to reach over to the other bin... LOL
Old Feb 17, 2006 | 10:58 AM
MLD211's Avatar
Or just use two big ones because I'm too lazy to reach over to the other bin... LOL </TD></TR></TABLE>
Ditto that^^
I usually call them positive and negative speaker terminals
Old Feb 17, 2006 | 02:43 PM
fcm's Avatar
fcm
Old Fart
Or just use two big ones because I'm too lazy to reach over to the other bin... LOL </TD></TR></TABLE>ROFL, not sure why that one cracked me up so much. 94
Old Feb 17, 2006 | 04:12 PM
cilvia's Avatar
Default Re: what are those aftermarket speaker to speaker wire adapter thingys called?? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> It's called a "female quick release" or "female disconnect" and it looks like this.... http://www.scosche.com/scosche...0-100
For most speakers you need a 0.250 for the pos. (+) term. and a 0.110 for the neg. (-). 94</TD></TR></TABLE>
does it come with the other end where you could pinch it to the speaker wire?? or is that a seperate name thingy??
Old Feb 17, 2006 | 05:44 PM
Look, just go to Circuit City and ask for a speaker adapter harness for your particular car. I don't know if that's what you're talking about exactly, but that is what you want. It will plug into the speaker plugs and have quick disconnect outputs for your aftermarket speakers.
Old Feb 17, 2006 | 11:58 PM
cilvia's Avatar
Default Re: what are those aftermarket speaker to speaker wire adapter thingys called?? (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Look, just go to Circuit City and ask for a speaker adapter harness for your particular car. I don't know if that's what you're talking about exactly, but that is what you want. It will plug into the speaker plugs and have quick disconnect outputs for your aftermarket speakers.
i snipped all the harnesses though cause before, i got lazy to order some and wanted to have it all setup asap...but HERE IS WHAT I WAS TALKIN ABOUT...i guess they come seperate end adapters than one piece...well i guess the blue/clear things are the female and male spade adapter thingys but what are the yellow/red things called that connect wires together?? and where can i get them??
Old Feb 18, 2006 | 08:02 AM
jdmotorsports's Avatar
butt connectors. get the 3m ones from home depot, skip the radioshack ones.
Old Feb 18, 2006 | 10:45 AM
cilvia's Avatar
Default Re: what are those aftermarket speaker to speaker wire adapter thingys called?? (jdmotorsports)
or most of the spade connector thingys mostly just one size in female and male?? because im bout ta just order a pack of em from ebay but none say the sizes of them so im guessing that all kinds of females and males are the same size right??
Old Feb 18, 2006 | 11:53 AM
just go to home depot. they sell it all. and most times aftermarket speakers have 2 different sized terminals.
teggy_617
Audio / Security / Video
Feb 5, 2010 01:25 PM
noob with an RS
Dec 29, 2004 09:41 AM
Hehehe I just
Aug 25, 2004 08:11 PM
pwrofdrm
Feb 18, 2004 05:27 PM
all420
May 30, 2003 04:30 PM
