I NEED HELP WIRING MY DECK
ok first i would like to stat i am a noob still when it comes to wiring ok with that out of the way the car is a 94 civic cx hatchback and the decck is a panasonice CQ-c1303u and i cant tell the wires apart so i needa noe wat goes where so here it goes
wires from car:
brown/white
brown/black < assume for speaker which sided
grey/white
grey/black < same which side speaker?
red/yellow
red/green < are these the rear speakers?
blue/yellow
blue/green < rear ?
yellow/red < battery?
white/blue
red/black < acc/ign?
black < ground?
wires from the deck:
Red (for power from acc or ign 12v )
black ( ground lead)
yellow ( battery lead 12v) its a thick wire
blue/white ( external amp control lead)
white (front Left + speaker)
white/black (front Left - speaker)
grey ( front right + speaker)
grey/black (front right - speaker)
thanks again
Modified by kyorishin at 10:29 AM 2/16/2006
Modified by kyorishin at 10:30 AM 2/16/2006
wires from car:
brown/white
grey/white
red/yellow
blue/yellow
blue/green < rear ?
white/blue
black < ground?
thanks again
ok nm i figured out the wiring codes by searcing but it wont turn on. i pluged all the wires up rite according to http://www.installdr.com but it still wont turn on. my ground and batter wires are thicker then all the other wires but would dat really make a diff when splicing into my old wires and crimping them together?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyorishin »</TD></TR><TR><TD CLASS="quote">ok nm i figured out the wiring codes by searcing but it wont turn on. i pluged all the wires up rite according to http://www.installdr.com but it still wont turn on. my ground and batter wires are thicker then all the other wires but would dat really make a diff when splicing into my old wires and crimping them together?</TD></TR></TABLE>
Is the key in the ignition?
Did you check the fuses under the dash, as well as in the engine bay? The one in the engine bay you need to check for is the one that says "BACKUP".
As for the wiring the difference in thickness shouldn't matter.
hondacivic90zc
Audio / Security / Video
Apr 12, 2021 05:17 PM
