AC Idle Pulley Question
The bearings on my AC idle pulley seized. The pulley and some of the other parts around it fell off while driving and where lost.
I was looking at the diagram below and it looks like there are two different sets of pulleys. I was wondering which set to buy? In the diagram I need parts 20, 19, 21, and 24. Or do I need the set labeled "2B"?
BTW 94 B18c1 in EG, no PS
Thanks
Mike
Modified by fakemike at 11:39 AM 2/16/2006
Thanks
Mike
I think thats 28 not 2B, anyway, when they make those diagrams they include other engines one may be for the B18B or your B18C, when you look up your car/engine everthing listed should only include the part numbers for your car.
I got that diagram by putting in all my all my info for the correct engine (B18c1)
and how do I get the part numbers from the diagram?
I got the diagram from http://www.acuraautomotiveparts.org
that side doesn't directly give you the part numbers, you know the list of parts at the bottom of all the diagrams, then it says "add to cart" etc. etc.
That list should only include YOUR numbers, you should see some of those numbers in the diagrams missing....those are for other cars.
you could try calling the dealer im sure they will give you the part number you need. i just changed mine. it sounded like a freaking super charger. it was so loud and on cold days it was insane.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4 coupe »</TD></TR><TR><TD CLASS="quote">you could try calling the dealer im sure they will give you the part number you need. i just changed mine.
Yeah i'll call the dealer and check part #s and prices. On acuraperformancepart.com the total for parts 20,19,21, and 24 came to $47 + s&h. Does that seem fair?
And when you had to reinstall the ac belt, was it hard to get the belt around that lower engine mount (it looks like a bitch)?
</TD></TR></TABLE>Yeah i'll call the dealer and check part #s and prices. On acuraperformancepart.com the total for parts 20,19,21, and 24 came to $47 + s&h. Does that seem fair?
seems fair to me i just went to the dealer and got mine. i paid almost double though
and im not sure about the mount... mine went right on no problem. no mounts were in the way.
99teggsr
Jul 5, 2013 05:36 PM
