need help w/ radio remove
i need to know how many screw that is holding the dash and the radio together. i try popping it out but it is too hard and dont want to break anything. im more of a integ guy then a civic but my bro got a civic and needed help. ooh and the civic is a 94 ex. need to know where to start to get to the radio. thanks
Re: need help w/ radio remove (lsvtec90)
theres 2 screws on each side of the console...from what i remmber..thats all..and then u pull that off..and theres 2 other screws holding the radio onto a metal bracket..
http://www.installdr.net
unscrew the bottom of the center console where the ash tray and cigarette lighter are. pull that off and u look up and see the radio.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec90 »</TD></TR><TR><TD CLASS="quote">is the screws block or is it where you can see it? anyone have pictures or a site where i can go ?</TD></TR></TABLE>
there on each side of the console..where i put the green dots..there on the side..where your legs would go....im pretty sure theres 1 on each side..but there might be 2..im not sure..then the whole face of the console comes off..there will be a wire you unplug..then you will be able to get the radio out..once you take off the other 2 screws that are under the console face that are going from the metal bracket to the radio..the radio should slide right out...hope this helps..i suck at explaning..but i hope this helps
edit: not my car..
edit: not my car..
JackRabbit
11-07-2008 11:33 AM
D50boy
04-03-2005 01:23 PM
