POWER Door Lock NOT working.....
Old Feb 16, 2006 | 02:29 AM
NVturbo's Avatar
O.G. triple O.G.
Default POWER Door Lock NOT working.....
Last night, I was trying to install an Excalibur ATV-1000 alarm on my friend's 1993 Civic coupe and ran into an issue. I have researched and it is stating that I should hook up the two (lock/unlock) wires from the alarm to the green/red-green/white wires found behind the under-dash fusebox. I tried both ways and it still doesn't work. I am aware that this model Civic is a TYPE-B negative trigger locking style. Anyone have a clue to make the power door locks work with the alarm? BTW, the door looks are still operating properly.
Old Feb 16, 2006 | 04:26 AM
B18C_EJ8's Avatar
Does that alarm have a jumper to switch between negative and positive pulses?
What happens if you touch the lock wires (that you're tapping into) to ground? Do they work then?
Old Feb 16, 2006 | 01:09 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Does that alarm have a jumper to switch between negative and positive pulses?
What happens if you touch the lock wires (that you're tapping into) to ground? Do they work then?</TD></TR></TABLE>No, the alarm does not have a jumper. I have NOT tried to touch the vehicle door lock wires to ground. I have read somewhere that you have to tap into the wires from a 3-wire plug (found behind the under-dash F/B) but somehow this car only has a 2-wire plug in which I have tried....to no avail.
Old Feb 16, 2006 | 02:00 PM
B18C_EJ8's Avatar
Try putting ground to the point where you tapped for locks... Then tell me if they work. You won't hurt anything.
Old Feb 16, 2006 | 02:17 PM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Try putting ground to the point where you tapped for locks... Then tell me if they work. You won't hurt anything. </TD></TR></TABLE>I'll try it out this weekend. Thanks
droopy128
Sep 22, 2018 05:47 AM
ROWSC
Honda Civic (2001 - 2005)
Apr 2, 2013 08:11 PM
doubleoazn03
Audio / Security / Video
Oct 7, 2010 02:29 PM
98greensi
Sep 28, 2010 08:58 AM
ketchup_gsr
Oct 28, 2002 08:55 PM
