smog and 200 hp
hey guys i have a d16z6 and would like to get 200hp to the wheels and still pass smog. i have plans to turbo it but would this also be a reliable daily driver . plan on doing some head work +.20 . port and polish the head, cams, cam gears, je pistions , and more stuff lol, its late. but my question is can i add this stuff and still pass smog.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist »</TD></TR><TR><TD CLASS="quote">umm, why only 200whp... thats still a 14-15 second car bro, also.. you will prob fail, just take the turbo off when you goto smog and base ecu. you'll be fine</TD></TR></TABLE>
200hp in my sol is a 13. definitely smog the car without the turbo.
My 93 EX Coupe + 195whp/164wtq = high 13s
I'm sure the same setup in a CX/VX will be a bit quicker too.
wrong, unless you cant drive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg_Ryan »</TD></TR><TR><TD CLASS="quote">My hatch has 182whp/162wtq and i hit 13.2 but really your best bet is to take off the turbo kit and have all the stock stuff to put back on or do it illegaly</TD></TR></TABLE>
Basically, take the spring out of the wastegate, put back in stock injectors, and ecu and you will pass... unless they do visual then:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 »</TD></TR><TR><TD CLASS="quote">wont you fail visual with a turbo?</TD></TR></TABLE>
Completely take off all the turbo parts to pass visual:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg_Ryan »</TD></TR><TR><TD CLASS="quote">really your best bet is to take off the turbo kit and have all the stock stuff to put back on or do it illegaly</TD></TR></TABLE>
wrong, unless you cant drive<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg_Ryan »</TD></TR><TR><TD CLASS="quote">My hatch has 182whp/162wtq and i hit 13.2 but really your best bet is to take off the turbo kit and have all the stock stuff to put back on or do it illegaly</TD></TR></TABLE>
Go with a turbo and low compression pistons instead of a thicker head gasket. The smog isn't an issue if you dynotune the vehicle to meet California emissions with the turbo on it. There is no need to remove the turbo, the ECU or injectors to pass California smog or TEST ONLY. The visual isn't an issue as long as the vehicle blows clean on the smog machine. Any vehicle can pass California smog regardless of the engine modifications. Turbo, JDM motors, or full race motors are no longer an issue to smog and register in California.
Please email me with any questions. Thank you.
Jay Garrett
Jay Garrett
