bought a NRG grounding kit, where are the good point to connect it?
Old Feb 15, 2006 | 11:53 PM
vietdragontekx's Avatar
Default bought a NRG grounding kit, where are the good point to connect it?
i bought a NRG grounding kit, and it come with that little circle thing to connect all the ground wire to. so do you just connect the wire to certain point of the car? anyone know where it good to connect to?
http://www.getnrg.com/nrggndwire_xx.php
Old Feb 16, 2006 | 03:33 AM
championshipwhite93si's Avatar
Default Re: bought a NRG grounding kit, where are the good point to connect it? (vietdragontekx)
not sure about the kit, but when i made my own, i went with all four gauge wire and i replaced the short battery to chassis ground and then i grounded at: the distributor, valve cover, intake manifold, alternator, tranny, block, and right near the header. just make sure to clean off your grounding spots good so theres good conductivity.
Old Feb 16, 2006 | 03:39 AM
hu's Avatar
hu
Doesn't it connect to the negative battery terminal?
Old Feb 16, 2006 | 04:31 PM
Default Re: (hu)
of course.
Old Feb 17, 2006 | 02:16 AM
hp92lude's Avatar
can anyone take pics of where those ground points are? i got some 4 gauge and looks like some of my grounds are nasty corroded and old so i wanna replace them all at once.
Old Feb 17, 2006 | 03:46 AM
killer hatch's Avatar
i got the same wires. i just connected them to the head bolts. thats how they recomend it. havent had any problem with it.
Old Feb 17, 2006 | 12:53 PM
Default Re: bought a NRG grounding kit, where are the good point to connect it? (killer hatch)
head bolts? which head bolts? you mean the four bolt that hold the valve cover down?
Old Feb 18, 2006 | 03:55 PM
ya my bad. connect them their and you will be fine.
Old Feb 19, 2006 | 11:24 AM
DIRTYsouthBB6's Avatar
Default Re: bought a NRG grounding kit, where are the good point to connect it? (championshipwhite93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by championshipwhite93si &raquo;</TD></TR><TR><TD CLASS="quote">not sure about the kit, but when i made my own, i went with all four gauge wire and i replaced the short battery to chassis ground and then i grounded at: the distributor, valve cover, intake manifold, alternator, tranny, block, and right near the header. just make sure to clean off your grounding spots good so theres good conductivity.</TD></TR></TABLE>
I think this guy has got it down pretty well... I'd connect it to points near important sensors and electrical devices that affect engine performance, aka the distributor, alternator, throttle position sensor, MAP sensor, spark plugs and wires, ignition coil, etc.
Old Mar 2, 2006 | 10:23 AM
Sl0wEK's Avatar
isn't the alternator positive?
Old Mar 4, 2006 | 08:04 PM
Default Re: bought a NRG grounding kit, where are the good point to connect it? (Sl0wEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sl0wEK &raquo;</TD></TR><TR><TD CLASS="quote">isn't the alternator positive?</TD></TR></TABLE>
LOL, not to the electrical terminal on the alternator, to the alternator mounting bracket.
Old Mar 4, 2006 | 11:25 PM
Skidtron89's Avatar
Default Re: bought a NRG grounding kit, where are the good point to connect it? (DIRTYsouthBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRTYsouthBB6 &raquo;</TD></TR><TR><TD CLASS="quote">
LOL, not to the electrical terminal on the alternator, to the alternator mounting bracket. </TD></TR></TABLE>
HAHA scary. I say hook it up to the alternator post and take a pic of what happens and post it on here. And to reiterate what this guy said the body of the alternator is not positive just the terminal where the stock positive wire is. That's why there is a piece of plastic under the terminal so the wire doesn't touch the body of the alternator and make fire and what not.
Old Mar 4, 2006 | 11:50 PM
M2B4's Avatar
Default Re: bought a NRG grounding kit, where are the good point to connect it? (Skidtron89)
thread jack but anyways did yall use gold connectors? if so where did you get? and did you use regular electrical wire? reason i ask is b/c i work at home depot and we only have copper connectors and our #4 wire dosent contain as many strands as the wires used on ground kits sold by apexi sun buddy club hks etc...
Old Mar 5, 2006 | 12:16 AM
Cottonwoodz's Avatar
Default Re: bought a NRG grounding kit, where are the good point to connect it? (M2B4)
Radio Shack..........
Spawne32
Jun 28, 2011 10:41 AM
jsnm
10
Mar 3, 2007 08:03 AM
Geeq
Aug 31, 2005 05:13 PM
JDM_lover03
61
Nov 22, 2004 07:38 AM
ravi
Jul 24, 2003 01:19 AM
