Turbo oil feed hookup.
Old Feb 15, 2006 | 11:09 PM
Jeffrey9's Avatar
Default Turbo oil feed hookup.
N00b question: I got this turbo oil feed line with my FMAX kit. I'm not familar, but will I have to drill a tap in the oil pan for this? Someone told me that it is possible to t it off the stock oil pump. Any input would be greatly appreciated.
Oh also, I have the H23 engine in case it matters.
Old Feb 16, 2006 | 04:11 AM
championshipwhite93si's Avatar
Default Re: Turbo oil feed hookup. (Jeffrey9)
looks like you take the oil pressure sending unit outta the back of the block, and screw that fitting in, and then screw the oil pressure sending unit into the other side of that fitting
Old Feb 16, 2006 | 05:00 AM
kulrevon's Avatar
Default Re: Turbo oil feed hookup. (championshipwhite93si)
you are going to have to drill and tap the oil pan for a oil return line.
but like championshipwhite93si said the goes where the sending unit is on the back of the h22 above the oil filter. and then the sending unit screws into that.
Old Feb 16, 2006 | 10:16 AM
chitownrida's Avatar
take off the stock oil sender ( grey rubber cap) below the oil filter. really close to the axle shaft
then screw that oil sender into the Tee you have pictured, then use the block adapter to screw into the T (usually a silver piece)
, then put the whole thing into the block
dont use the T directly on the block. i dont think its the correct thread and it will leak
Old Feb 16, 2006 | 12:19 PM
skrewdlude's Avatar
Default Re: (chitownrida)
You can use the oil port in the head right next to the vtec solenoid/pressure sensor. There will be a hex plug in it. Take out the plug, and put this line on.
Old Feb 16, 2006 | 01:41 PM
Jeffrey9's Avatar
Default Re: (skrewdlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdlude &raquo;</TD></TR><TR><TD CLASS="quote">You can use the oil port in the head right next to the vtec solenoid/pressure sensor. There will be a hex plug in it. Take out the plug, and put this line on. </TD></TR></TABLE>
Well, assuming I even had vtec, the fact that the fluctuating oil pressure off the selonoid doesn't play well with the seals on the turbo somewhat discourages me from doing it.
Old Feb 16, 2006 | 01:42 PM
Jeffrey9's Avatar
Default Re: (Jeffrey9)
Also, where can I find that adaptor you guys mentioned?
Old Feb 16, 2006 | 02:06 PM
skrewdlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeffrey9 &raquo;</TD></TR><TR><TD CLASS="quote">
Well, assuming I even had vtec, the fact that the fluctuating oil pressure off the selonoid doesn't play well with the seals on the turbo somewhat discourages me from doing it.</TD></TR></TABLE>
Sorry I forgot it is an h23. Just to clarify, that port does not fluctuate with vtec, and I believe it is in the same spot on an H23. It gets constant oil pressure.
Contact stan at fast turbo for the adapter.
Old Feb 16, 2006 | 02:12 PM
Jeffrey9's Avatar
Awesome thanks. Will do
LudeyKrus's Avatar
I'll save you the heartbreak now. Don't use the brass tee right off of the back of the block. The brass work-hardens after many miles and will become very brittle, and will often break off and let the oil spray out the back while you're driving down the road.....
Old Feb 16, 2006 | 04:19 PM
if your worried about the T breaking in the block use a sandwich adapter
i have one for sale btw
lol
ben
Old Feb 17, 2006 | 01:00 AM
Jeffrey9's Avatar
Is the sandwich adapter that same one you were referring to when you said I'd need one to match the tee to the block?
Old Feb 17, 2006 | 06:59 AM
kulrevon's Avatar
if you don't want to use the tee you can use something like this sandwhich plate that goes inbetween the oil filter and the block.
Old Feb 17, 2006 | 07:02 AM
skrewdlude's Avatar
No, a sandwich adapter goes between the oil filter and the block. It has ports on it to allow you to run oil lines directly from there.
The adapter you need for the block will look like this:
Fast-Turbo sells a kit, it comes with the adapter, and 3ft of steel braided line so you can mount the t on the firewall. It also comes with new tees.
Old Feb 17, 2006 | 09:36 AM
i also asked stan about the T breaking off in the block. he says if you use the right adapter like pictured above, it wont be an issue
stan@fast-turbo
Old Feb 18, 2006 | 01:02 AM
Jeffrey9's Avatar
Awesome. I appriciate all the good info.
balbowskie
Feb 17, 2012 06:47 PM
big-cat
Jun 15, 2007 03:53 AM
jdmcx
Apr 7, 2004 06:38 AM
justinCO
Oct 28, 2002 01:07 PM
Spade
Mar 15, 2002 06:36 AM
