93 GSR brake conversion?
Old Feb 15, 2006 | 07:02 PM
Rev Red's Avatar
Default 93 GSR brake conversion?
i was just wondering if i was to get a 93 GSR front caliper, caliper mount or bracket whatever its called, and rotors. would it fit on the stock 91 crx suspension. i believe it would cause their both basically the same. just want ot know for sure if anyone knows
thanks
give me good new people
Old Feb 15, 2006 | 07:46 PM
red_EF9Si's Avatar
Default Re: 93 GSR brake conversion? (Rev Red)
the good news is you can find this info and more simply by searching
give it a try sometime
Old Feb 15, 2006 | 08:27 PM
EL Vap133's Avatar
Default Re: 93 GSR brake conversion? (red_EF9Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_EF9Si &raquo;</TD></TR><TR><TD CLASS="quote">the good news is you can find this info and more simply by searching
give it a try sometime </TD></TR></TABLE>
Old Feb 16, 2006 | 10:31 AM
Rev Red's Avatar
thats the first thing i did i couldnt find anything so then i asked
Old Feb 16, 2006 | 10:38 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rev Red &raquo;</TD></TR><TR><TD CLASS="quote">thats the first thing i did i couldnt find anything so then i asked
Really? I got this result:
» Search Results
Your search for Integra brakes returned 55 results.
» New Search
Old Feb 26, 2006 | 01:34 PM
infested's Avatar
be advised! DONT DO IT. the hub assembly from a 93 is different and the geometry of the suspension set up will not be the same. I've heard of many people doing on their crxs but ran into camber issues that are difficult to fix. not to mention that your tires will be bulging from the fender well..... (ugly).. anyways... if you want dope *** brakes, just get a big brake kit from willwood or rotora. less than 1000 bucks and you will be braking so fast it will scare you....
Old Feb 26, 2006 | 05:36 PM
mahatma's Avatar
Default Re: 93 GSR brake conversion? (infested)
It will work and work well. And camber problems are very minor. Just lower your car a little and voila.
Don't spend no honkin $1k!!!
JUST DO IT!
aznguy0087
Apr 8, 2007 12:59 PM
revin=smiles
Suspension & Brakes
Jun 2, 2005 11:52 AM
Jdm93civic
11
Mar 8, 2005 09:27 AM
vicz
Mar 26, 2003 09:21 PM
Clean.CL
Jan 18, 2003 12:31 AM
