D16Y8 running P28 ecu
Old Feb 15, 2006 | 06:21 PM
brusk13's Avatar
Default D16Y8 running P28 ecu
Ok I've got some intermittent check engine codes for some stupid reason. If I switch over to a P28 ECU would it run ok. I've heard before that it won't run right but I don't see any reason. The engines are close enough, hell if you can run a Y8 on a Y7 ecu why not. It's in a manual 96 CX with a Y8 harness, engine and ecu from a 98
Old Feb 15, 2006 | 07:48 PM
Everyones Hero's Avatar
Default Re: D16Y8 running P28 ecu (brusk13)
It'll run, but it'll run like ****. The timing on the Z6 and Y8s is very different.
Old Feb 16, 2006 | 05:13 PM
JUST2SPOOL's Avatar
I AM A SCAMMER, DO NOT BUY ANYTHING FROM ME.
Default Re: D16Y8 running P28 ecu (Everyones Hero)
Humm
Old Feb 16, 2006 | 06:46 PM
mann's Avatar
mine runs pretty damn good...d16y8 in a 95 del sol obd1 on a p28. 27mpg beating on it 35 highway.
Old Feb 18, 2006 | 11:49 AM
brusk13's Avatar
does the Z6 have more or less timing than the Y8. I'm guessing less, which might be ok since my Y8 has 10.5:1 CR that might be enough to make up for the cam difference.
2dr CRX
Jun 4, 2013 11:45 AM
user 98292739
Nov 23, 2007 03:11 PM
sanegb16
Oct 16, 2007 11:21 PM
JH4DC231
Aug 12, 2006 10:30 PM
