my 2003 rsx automatice wont go into reverse!?
wont engage reverse when shifted from park to reverse position. also wont shift from nuetral to reverse unless i put it in drive first. all nthis happened after i got in an accident and my friend that works at an acura dealer replaced the cases.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanddriver »</TD></TR><TR><TD CLASS="quote">wont engage reverse when shifted from park to reverse position. also wont shift from nuetral to reverse unless i put it in drive first. all nthis happened after i got in an accident and my friend that works at an acura dealer replaced the cases.
well then your friend screwed up it sounds like the PNP switch is not set right
</TD></TR></TABLE>well then your friend screwed up it sounds like the PNP switch is not set right
yeah now you are describing a different problem most likely you have bad trans some of the clutchs could be bad or possibly the torque converter
Poroshok
Transmission & Drivetrain
Jun 14, 2009 09:59 AM
Jparkerbd
14
Sep 10, 2006 05:27 AM
