B16a head gasket leaks coolant outside below the distributor.. This a concern?
Old Feb 15, 2006 | 11:03 AM
crx00's Avatar
Default B16a head gasket leaks coolant outside below the distributor.. This a concern?
I just noticed my head gasket is leaking coolant (more like sweating)in the area below the distributor. Is this something I should address ASAP? It doesn't lose a lot of coolant but it shouldn't be losing any at all. Thanks!
Old Feb 15, 2006 | 11:04 AM
splitime's Avatar
Default Re: B16a head gasket leaks coolant outside below the distributor.. This a concern? (crx00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx00 &raquo;</TD></TR><TR><TD CLASS="quote">I just noticed my head gasket is leaking coolant (more like sweating)in the area below the distributor. Is this something I should address ASAP? It doesn't lose a lot of coolant but it shouldn't be losing any at all. Thanks!</TD></TR></TABLE>
Double check the coolant hose that is right there... i bet the clamp is loose or the hose is getting old. I bet that is the source of your leak.
Old Feb 15, 2006 | 11:21 AM
mar778c's Avatar
Community Builder
Community Influencer
Check the hose for sure, but it sounds like you will need a new head gasket. The classic sympton is antifreeze right at the front corner of the block/tranny, passenger side.
kelviiv
Feb 26, 2008 07:26 PM
boostedNOTHARDLY
Dec 4, 2007 07:27 PM
Vtecme92
Jun 30, 2006 02:45 AM
seeeya04
Dec 6, 2005 11:48 AM
hb_guy
Oct 29, 2005 06:12 PM
