Tower speakers with two terminals...wiring?
Old Feb 15, 2006 | 10:37 AM
watacivic's Avatar
Default Tower speakers with two terminals...wiring?
should i wire in a series or parallel them to get optimum performance? thanks
Old Feb 15, 2006 | 11:20 AM
B18C_EJ8's Avatar
Two terminals, like a positive and a negative? Not sure what you mean by tower speakers. Are we talking home audio here?
Old Feb 15, 2006 | 02:05 PM
watacivic's Avatar
Default Re: (B18C_EJ8)
yes..the towers are home audio.. the speakers have 2 sets of terminals on the back..2 positives and 2 negatives
Old Feb 15, 2006 | 03:08 PM
B18C_EJ8's Avatar
What does the manual for the speakers say??
What kind of speakers are these? What is the ohm rating on the speakers?
What is the ohm rating on your amplifier/receiver???
All questions that need to be answered to determine an answer...
Old Feb 15, 2006 | 09:17 PM
watacivic's Avatar
The manual is very vague. It just says how I should place the speakers in a room. It shows how to hook the speaker up but using only one terminal set and the towers have two sets in the back so I'm pretty sure I have to hook up both sets. But here are the answers:
Advent Heritage H500 speakers made by Audiovox. 4-4" midranges and 1" soft dome tweeter. Frequency response: 35Hz-30kHz. Nominal Impedance: 4-8 ohms. Sensitivity: 89dB. Recommended Power: 10-200 watts.
Harman Kardon DPR 2005: 7-Channel power, 120 watts x 7 per channel @ <0.15% THD, 20Hz – 20kHz into 8 ohms. THD @ impedance: 0.15% @ 8 ohms
Thanks
Old Feb 15, 2006 | 11:23 PM
96civicHATCH's Avatar
Default Re: (watacivic)
when it says nominal impedance 4-8 ohms, its letting you know that if you hook up one set of terminals it will have an impedance of 8 ohms, both=4 ohms. your receiver puts out 120watts at 8 ohms, you're fine with doing just one set of terminals.
Even if your recevier is capable of 4ohms (most likely not, the only other impedance receivers can handle are 6ohms) you would be doubling the output of the recevier which is 240watts and is not recommended for the speaker.
Old Feb 16, 2006 | 05:22 AM
Hondaaccordvtec's Avatar
Default Re: (96civicHATCH)
If you have 2 sets of terminals on the backs of your speakers, it means they are capable of being "bi-amped" / "bi-wired" / or both. Your speakers should have come w/ "jumper" pins that connect both sets of terminals. Just hook your speaker wire up to 1 set of terminals on each speaker and call it a day.
Old Feb 16, 2006 | 09:00 AM
watacivic's Avatar
Default Re: (Hondaaccordvtec)
it didnt come with any jumper pins, at least i didnt see it on the back. But I appreciate it guys...learn something new everyday
91akira
Audio / Security / Video
Feb 21, 2010 06:15 PM
imadigitalgod
12
Nov 13, 2009 01:58 PM
PatrickGSR94
Feb 21, 2005 08:11 PM
juniordc2
12
Jun 4, 2002 11:07 PM
GoLowDrew
Jul 12, 2001 03:38 PM
