GSR Oil pan swap onto LS...Need to change pickup???
Old Feb 15, 2006 | 10:29 AM
Baggy Spandex's Avatar
Default GSR Oil pan swap onto LS...Need to change pickup???
91 LS...putting a P72 pan on it, will I need to change pickups/windage tray? Or should this be a simple swap?
Old Feb 15, 2006 | 10:58 AM
DC2 Mang's Avatar
Default Re: GSR Oil pan swap onto LS...Need to change pickup??? (NAisBEST)
shouldnt have to, but how come you are putting a gsr pan on? are if going to use the gsr girdle? if you are then yes you will need to change the windage tray and pickup
Old Feb 15, 2006 | 10:59 AM
Default Re: GSR Oil pan swap onto LS...Need to change pickup??? (JDMdc2lsVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec &raquo;</TD></TR><TR><TD CLASS="quote">shouldnt have to, but how come you are putting a gsr pan on? are if going to use the gsr girdle? if you are then yes you will need to change the windage tray and pickup</TD></TR></TABLE>
JDM 4-1 hits the LS pan but...it doesnt hit if you swap tp a P72
Old Feb 15, 2006 | 11:01 AM
DC2 Mang's Avatar
it should swap right over then without problems
Old Feb 15, 2006 | 11:02 AM
DC2 Mang's Avatar
a b16 pan my work as well but im not sure on that one about clearance
Old Feb 15, 2006 | 11:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec &raquo;</TD></TR><TR><TD CLASS="quote">a b16 pan my work as well but im not sure on that one about clearance</TD></TR></TABLE>
B16 and LS are the same I believe.
Thanks for the info bro
Old Feb 15, 2006 | 03:24 PM
for a definite answer through experience
B18A1 W/ P72 oil pan
Death_to_Thieves
Nov 4, 2006 05:53 AM
Turbocivic94
Jul 22, 2005 09:10 AM
nonvtec
Oct 25, 2004 10:27 AM
baonest1
Nov 2, 2002 07:23 AM
dohcsideSi
Jan 3, 2002 10:55 AM
