rear alignment, what is adjustable?
Old Feb 15, 2006 | 08:16 AM
drew2's Avatar
Default rear alignment, what is adjustable?
I just put Energy suspension bushings in my rear suspension and changed the trailing arm bushing. Do i need to get the car aligned now? I dont see what part of the rear suspension is adjustable.
Old Feb 15, 2006 | 09:38 AM
rsca_crx's Avatar
Default Re: rear alignment, what is adjustable? (drew2)
the rear is adjustable for toe. (adjuster is the slotted body mount at the front of the ta) if you took the ta off (which you probably did to to the ta bushing) you need an alignment.
Old Feb 15, 2006 | 10:04 AM
Targa250R's Avatar
be professional
Yep, if you removed the trailing arm and/or the toe compensator arm, you will need an alignment.
Old Feb 15, 2006 | 12:52 PM
drew2's Avatar
Default Re: rear alignment, what is adjustable? (Targa250R)
cool, thanks for the help
Old Feb 15, 2006 | 03:41 PM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">Yep, if you removed the trailing arm and/or the toe compensator arm, you will need an alignment.</TD></TR></TABLE>
Scrpn17w
Apr 1, 2009 06:28 PM
sk8shorty012
15
Mar 7, 2007 05:10 PM
suspendedHatch
Suspension & Brakes
Apr 18, 2006 09:27 PM
cbmprelude
Suspension & Brakes
26
Nov 9, 2005 12:39 PM
crxgator
14
Jul 26, 2004 08:57 AM
