Installed a new b16 longblock and tranny grinds into every gear
Old Feb 15, 2006 | 05:49 AM
teler86's Avatar
Default Installed a new b16 longblock and tranny grinds into every gear
like the title says I installed a new b16 longblock and the tranny grinds into every gear. what could this be my clutch pedal feels crazy loose, and i can shift into gear when the car is off???. I took off my tranny because i thought it could of been that there was no throw out bearing in it, but there was one, i replaced it anyways. Any advice on what it could be would be appreciated.
Old Feb 15, 2006 | 06:07 AM
h224thgensedan's Avatar
check your cable. It might be real loose or if its hydrolic bleed the clutch.
Old Feb 15, 2006 | 09:21 AM
tek_civic's Avatar
agreed... if the cable is to loose, your really never putting in the clutch at all. which means the trans is still spinning when you try to shift. this can make it difficult to shift without grinding. def adjust the cable(same goes for hydro clutch)
shoklid
17
May 7, 2009 07:56 AM
rexfan
Transmission & Drivetrain
Nov 4, 2008 04:39 PM
XLR8_HFX
Feb 12, 2008 08:38 AM
VtecDA9
Nov 22, 2006 08:14 AM
illestrolla247
Sep 19, 2004 08:27 PM
