Trying to remove crank but cant get the woodruff key out..PLEASE HELP
Im trying to get the crank out of my h22 but i cant seem to get the key out so i can slide the crank gear off. please help
so the key is just stuck on the shaft? spray it with some lube, give it a little tap tap with a blunt object. thats really odd, is it rusted or somthing?
Finally got the bitch out...I had to remove everything on the side of the motor so i could tap the oil pump plate to push the crank gear off.
