REPAINT OEM LIPS??
Can you repaint OEM civic lips?? Mine is pretty much shot to **** and looks like **** time to clean it up. If I wetsanded it down it all even and resprayed it would it hold up to the restoration??
You should have no problem as long as you respray it properly. I respayed my buddy's entire door using Duplicolor products and it looks as good as an actual shop did the painting. But keep in mind that i also used to work for a paint shop so i know a little about how to paint.
But for a small project like the lip you should have no problem. Check out the Duplicolor line of paints they have an awsome line of prducts that will match your factory paint as long as you take your time and respray properly it should turn out great!
hancho
Jun 14, 2003 08:16 AM
