transmission or what? please help
i swapped a built d16z6 into my 94 coupe and ever since the swap u push the clutch in and the idle dies down and sometimes dies but as soon as u let the clutch out the rmps goes back up and everythings ok what could cause this
is ur clutch possibly going? If so it would be like letting out the clutch w/o giving it gas (when in gear). Does it happen when the stick is in neutral? (not neutral by way of clutch)
so if you just start up you car (in neutral), leave it alone, let it warm up, go outside (or garage, whatever), and get in, and step on the clutch (nothing else, no AC, heater, radio, etc.), the RPM's go low and sometimes stall out?
highly doubt its the throw out bearing...
mine does it to but not as bad as urs...
same thing when u turn ur lights on, ur rpms drop a little or pump ur brake, rpms rise a little???
