advance timing
Old Feb 14, 2006 | 01:43 PM
wrinkles's Avatar
Default advance timing
i want to advance the timing of my 97 dx stock d16 engine, i want to know if i will gain anything from this and if so how should i go about doing it.
IHateJDM's Avatar
Default Re: advance timing (wrinkles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrinkles &raquo;</TD></TR><TR><TD CLASS="quote">i want to know if i will gain anything from this </TD></TR></TABLE>
nope
Old Feb 14, 2006 | 02:10 PM
Relic1's Avatar
maybe 2-5hp max and you will have to run premium fuel all the time.
how-to
run your tank empty and fill up with premium.
add 2 degrees timing with a timing light. (3 if you're feeling lucky and don't abuse the car)
reset ECU and let idle for 10 minutes.
Old Feb 14, 2006 | 03:25 PM
SL!M's Avatar
Probably not much good. Why do that?
Old Feb 14, 2006 | 03:39 PM
wrinkles's Avatar
i would have to run premium fuel?
and i was just wondering if there were any ways to get quick hp.
Old Feb 14, 2006 | 04:08 PM
IHateJDM's Avatar
Default Re: (wrinkles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrinkles &raquo;</TD></TR><TR><TD CLASS="quote">i would have to run premium fuel?
and i was just wondering if there were any ways to get quick hp.</TD></TR></TABLE>
you would need higher octane gas to prevent detonation, but even then the gains are minimal. I don't think you would even see 2 hp.
Old Feb 15, 2006 | 07:14 AM
SL!M's Avatar
Don't screw with the timing unless you know what you are doing. You are just going to give yourself a headache. Start reading books, not asking questions on forums if you are going to do deep into tweaking things.
Old Feb 15, 2006 | 10:27 AM
aXhatch's Avatar
Default Re: (Relic1)
actually it might not be a good idea to run the fuel tank empty
Im not saying all, but a fair few hondas I ahve worked on have done things like that after a motor swap (from d-b for example, last week..) running the fuel pump dry can be bad for it, and blow it. basically you ahve the chance of rendering it useless.
what you could do is to run the tank very low (if you are advancing the timing, but as other replys state, not a really worthwhile upgrade for you yet) and then, before you put permium in it, throw in a bottle of 104 octane booster. if thats at the bottom of your tank, with the "bad" gas, it should mix up while you put prem. in it. After a few tanks, all of the reg. gas should be completly cleaned out of your system.
Old Feb 15, 2006 | 11:50 AM
aquabob89's Avatar
* B A N N E D *
Default Re: (aXhatch)
I wouldn't mess with the timing if I were you. If you have stock parts then just use stock timing. I messed my car all up by doing that. Because at first I didnt have a timing light. Also no gains and your car will run rich.
flamega
Feb 7, 2007 08:04 AM
Fusion G2 Civic
Jan 5, 2006 04:39 PM
hxtasy
Jul 20, 2005 05:16 AM
88championrex
Jan 19, 2005 09:10 AM
platinum00
Dec 17, 2004 08:53 AM
