Turbo D15b7...
Alright well im sticking with the D15B7 head and going to turbo it in a month, well i ordered the ARP bolts so far what else so i wouldnt go blowing this small engine
What size head gasket would you prefer? nothing over 10 PSI (for now)
umm a commonly overlooked piece that (if you do ur turbo set up right) will greatly reduce the chance that you'll blow your engine, is a turbo timer....and thats my two cents on this topic lol
what the hell does a turbo timer having to do with blowing the motor??????? a turbo timer is used to allow the center cartridge/bearing in the turbo to cool before shutting down the car, nothing else.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">what the hell does a turbo timer having to do with blowing the motor??????? a turbo timer is used to allow the center cartridge/bearing in the turbo to cool before shutting down the car, nothing else.</TD></TR></TABLE>
because the oil can turn hard from the intense heat that the turbo creates, thus, if you dont let ur turbo cool down that makes your oil a lil denser and the more and more you do that the worse it is for your engine. Making a simple 3000 mile replacement to about 1000 or less, and if you dont realize it and go on for 3000+ miles, well, i dont want to know what the engine will look like
