00 interior conversion
Old Feb 14, 2006 | 12:36 PM
tobe1424's Avatar
Default 00 interior conversion
if i would get the a/c and radio console of a 00' ek would it plug and play into a 96 ek hb or would i have to do some custom wiring?
Old Feb 14, 2006 | 12:37 PM
.Beaver's Avatar
Bloody Beaver
Default Re: 00 interior conversion (tobe1424)
you need the 99-00 Heatercore and blower, and the sub harness.
Old Feb 14, 2006 | 12:44 PM
tobe1424's Avatar
Default Re: 00 interior conversion (.Beaver)
so i would have to do some custom wiring or after i get all that it plugs into everything
Old Feb 15, 2006 | 07:12 PM
aF's Avatar
aF
You need the 99-00 dash harnness.You don't need the heater core or blower.you just need the climate controls and dash harnness.I would suggest getting the 99-00 dash because the heater vents are centered on the 96-8 heater control and to the one side on the 99-00.Or get the air ducts from a 99-00.You have to remove the dash to swap the harnness.you will notice there is a blue plug that comes from the firewall harnness(on the passenger side) .Just remove your old harnness, plug the 99-00 harnness there and into the fuse box,etc,etc...I have done the conversion a couple times now.Let me know if you need anymore info..
Old Feb 15, 2006 | 07:29 PM
aF's Avatar
aF
Default Re: 00 interior conversion (aF)
To add to my last post,if you are planning to add a/c,you need the evaporator core and the box.If you all ready have a/c you will be fine.
Old Feb 15, 2006 | 07:30 PM
.Beaver's Avatar
Bloody Beaver
https://honda-tech.com/zerothread?id=605432
Old Feb 15, 2006 | 08:42 PM
jdmpsicivic's Avatar
good luck
Old Feb 15, 2006 | 10:02 PM
zerovandez's Avatar
I did it, it's not all that hard. Just be patient follow directions on the link that was given to you earlier. It's pretty much all plug n play except for the rear defroster. You can use this link too:
http://repo.jackmoves.com/v/erik/album106/album228/
That should answer all of your questions!
Old Feb 15, 2006 | 10:43 PM
wutthebun's Avatar
anyone want to do this conversion for me in socal??
Old Feb 16, 2006 | 08:34 PM
tobe1424's Avatar
alright thanks man this was very helpful
bart simpson
Mar 14, 2010 07:55 PM
import-tooner
Dec 16, 2009 05:48 PM
import-tooner
Apr 5, 2009 07:36 PM
ThE BiG RauL
Oct 29, 2008 12:30 PM
