Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
brake pedal goes to floor. HELP!
Old Feb 14, 2006 | 12:06 PM
ekian's Avatar
Default brake pedal goes to floor. HELP!
I have a 1996 Honda Civic CX, that comes originally with rear drums. I bought a 1997 Honda Integra Type R 4x114.3 suspension and brakes so that I could convert my drums to discs. While I had everything off, I went ahead and upgraded a few things. I am using a 2000 Honda Civic Si master cylinder and 40/40 proportioning valve, 2001 Acura Integra Type R front brake calipers, and 1995 Honda Prelude front brake rotors.
Now, my problem. I have the softest pedal in the world when I start the engine. The brakes do not even stop the car at all. I have to use the ebrake. Take note that I have not left my driveway with the car in this state. I have bench bled the master cylinder twice. I have spent about 2-3 hours bleeding each caliper and have gone through 4 large bottles of brake fluid. I have checked the Helm's manual page that .RJ posted to diagnose if it could possibly be the brake booster or even the master cylinder.. no dice. I do not know what else to do now.
I would really appreciate any help and insight you guys could give.
thanx.
Old Feb 15, 2006 | 10:01 AM
ekian's Avatar
Old Feb 15, 2006 | 10:08 AM
Xian's Avatar
Default Re: (ekian)
Is the pedal also soft without the engine running?
Old Feb 15, 2006 | 10:09 AM
Honda318dx's Avatar
Default Re: (ekian)
If its going to the floor softly with next to no pressure, the MC is shot.. Even if you had a little air in the line, it would still stop the car..
Old Feb 15, 2006 | 11:18 AM
granracing's Avatar
When the car is off and you pump the brakes, do they become firm?
Old Feb 15, 2006 | 04:11 PM
ekian's Avatar
Default Re: (granracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xian &raquo;</TD></TR><TR><TD CLASS="quote">Is the pedal also soft without the engine running?</TD></TR></TABLE>
no! only soft when there is vacuum = car is running
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granracing &raquo;</TD></TR><TR><TD CLASS="quote">When the car is off and you pump the brakes, do they become firm? </TD></TR></TABLE>
yes! rock hard.
i'm gonna put the stock MC back on and see if that does the job.
if so, i'm gonna take the 7/8ths Si MC back and get a 1" ITR.
thanx so far guys.
Old Feb 16, 2006 | 07:30 PM
MightyMouseTech's Avatar
Default Re: (ekian)
Um, you CAN NOT use a master cylinder from a car with ABS on your car unless your car also came with ABS. The brake boosters are different between ABS and non-ABS cars, and the master cylinders can not be switched between them. Get a brake booster from the 2000 Civic Si as well. That should fix ya up.
Old Feb 16, 2006 | 07:48 PM
ekian's Avatar
Default Re: (MightyMouseTech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekian &raquo;</TD></TR><TR><TD CLASS="quote">I am using a 2000 Honda Civic Si master cylinder and 40/40 proportioning valve....</TD></TR></TABLE>
thanx though.
laurentj23
Jan 28, 2012 06:55 AM
starlily61
Jul 13, 2007 12:38 PM
ekian
13
Feb 16, 2006 06:24 AM
AzDrag1
May 14, 2003 02:53 PM
bruvaman
Jul 9, 2002 07:19 PM
