ecu question
Now im kinda new to this whole ecu thing. My set up is 92 teg wit b18a head and block. .25 over CTR's, 310cc injectors, exedy stage one racing clutch, ram intake, DC 4-1 header, and crower 404's and dual valve springs and retainers wit a PnP, 3 angle valve job, and a b16 J1 tranny. all tuned wit a vafc. now i know i have a vafc now if i want to upgrade to hondata, chrome, or phearable ect...... what is it that i must do?
check to see if your ECU is able to be used, if not convert to one that is and aquire one.
remove VAFC
install supplies into ECU required to run what ever system you want (search how-to chip ECU)
create base map and install into ECU
tune
if you need more info than that check out pgmfi.org and read the WIKIs
http://www.pgmfi.org/twiki/bin...bHome
then check out the forum....
remove VAFC
tune
Speed Infliction
Jun 9, 2006 09:26 AM
AK94GSR
Oct 4, 2002 03:02 PM
