Injectors or fuel pump/regulator
Old Feb 14, 2006 | 09:26 AM
redGSRguy's Avatar
Default Injectors or fuel pump/regulator
The guys tuning my car said it is lean 7k+. They suggested to go either injectors or a fuel pump/regulator.
Is one path better than the other? Any suggestions on which path and brands to go with?
Old Feb 14, 2006 | 09:42 AM
sQwiReL bOi
Guest
Posts: n/a
you gotta be a little more specific. do you have stock injectors and fuel pump/regulator at the current moment? tell us more to help you.
Old Feb 14, 2006 | 10:56 AM
redGSRguy's Avatar
Default Re: (sQwiReL bOi)
Yes sorry, stock injectors and stock fuel pump/regulator. Blox intake manifold and running hondata.
Old Feb 14, 2006 | 11:00 AM
Nick M's Avatar
Default Re: (redGSRguy)
more info
Old Feb 14, 2006 | 11:09 AM
redGSRguy's Avatar
Default Re: (Nick M)
Blox spec C cams, jdm o/s itr pistons, ARP head/main studs and rod bolts, portflow head, supertech flat faced valves, rocket gen 2 springs/retainers and a red(!) valve cover.
Planning on having it tuned to 9k once I get the injectors and or fuel pump/regulator.
sQwiReL bOi
Guest
Posts: n/a
be specific with internals. if you dont have any and all your running is the blox intake manifold then you should be fine with fuel delivery. might want to look at how your hondata is set up with fuel.
Old Feb 15, 2006 | 07:35 AM
redGSRguy's Avatar
Gave a few more specifics, anything else you guys need to know? I am thinking of just going with the Delphi injectors on sale from project.dc2...
Old Feb 15, 2006 | 02:23 PM
BlUeHoOdCiViC99's Avatar
how about the MSD 395cc injectors anybody used them before
buckysi
Mar 6, 2006 03:54 PM
hybridEj6
Jan 31, 2005 01:42 PM
jeremy.
Sep 29, 2003 05:35 PM
