The Intentional Destruction of Laboriously Engineered Artifacts - A Pictorial
Old Feb 14, 2006 | 09:18 AM
revolt_allmotor's Avatar
Default The Intentional Destruction of Laboriously Engineered Artifacts - A Pictorial
Finally got around to dissassembling my LS/VTEC which suffered catastrophic failure about 4 months ago. Been busy with work and putting together another motor, I knew it was broken but now I decided to look at the damage in detail, here's what I found....
here's the debris in the oil pan
you can kinda see all the crap in the pickup screen....
#3 rod and what's left of the bearing....
#3 rod journal with some more bearing material stuck to the crank....
#2 rod - this is what the rest of the bearings looked like, just all scuffed up...
and yes the thread title was plagarized you get ten bonus points if you can tell me where it came from....
Old Feb 14, 2006 | 09:20 AM
Default Re: The Intentional Destruction of Laboriously Engineered Artifacts - A Pictorial (revolt_allmotor)
not sure yet as to cause of death. I originally suspected a broken oil pump gear but on dissassembly the oil pump is fine. also the main bearings don't look too bad, just scored up from debris in the oil.
this motor was SEIZED - I could barely turn it over with a 4-foot breaker bar on the crank pulley bolt
Old Feb 14, 2006 | 10:04 AM
Chris22215's Avatar
damn at the crank
Old Feb 14, 2006 | 10:23 AM
onlinehost's Avatar
Default Re: The Intentional Destruction of Laboriously Engineered Artifacts - A Pictorial (Chris22215)
hey edge is it from army of darkness the streetbike club
Old Feb 14, 2006 | 10:24 AM
Default Re: The Intentional Destruction of Laboriously Engineered Artifacts - A Pictorial (onlinehost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onlinehost &raquo;</TD></TR><TR><TD CLASS="quote">hey edge is it from army of darkness the streetbike club </TD></TR></TABLE>
ten bonus points for you sir!
Old Feb 14, 2006 | 10:25 AM
onlinehost's Avatar
yea fo sho
Old Feb 14, 2006 | 10:34 AM
VtecKiDD's Avatar
i googled it and thats what it said, do i get 1 point at least???!!
Old Feb 14, 2006 | 01:13 PM
Default Re: The Intentional Destruction of Laboriously Engineered Artifacts - A Pictorial (VtecKiDD)
for sure lol
Old Feb 14, 2006 | 01:38 PM
ITRnorway's Avatar
is it a crack on youre crank on the second last image?
Old Feb 14, 2006 | 02:07 PM
Default Re: (CRXnorway)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXnorway &raquo;</TD></TR><TR><TD CLASS="quote">is it a crack on youre crank on the second last image? </TD></TR></TABLE>
no it's a piece of the bearing that is melted onto the crank but it's lifted off at the very edge...
here's another pic (#2 and #3 rod journals....)
Old Feb 14, 2006 | 05:15 PM
Default Re: (revolt_allmotor)
oh yeah there was TONS of debris in the oil when I drained it. and pieces of bearing in the oil filter lol. so I knew right away I was fucked.
Old Feb 15, 2006 | 04:29 AM
ITRnorway's Avatar
wow, that was scarry. was it OEM bearings? do you think it was cheap oil or was it a long time since last oil change?
Old Feb 15, 2006 | 09:44 AM
mchuang's Avatar
are those stock ls rods with stock rod bolts?
Old Feb 15, 2006 | 12:45 PM
UncleD's Avatar
Default Re: (mchuang)
Eeeeeeeeee, no bueno!
Old Feb 16, 2006 | 08:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mchuang &raquo;</TD></TR><TR><TD CLASS="quote">are those stock ls rods with stock rod bolts?</TD></TR></TABLE>
yeah
Old Feb 16, 2006 | 08:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXnorway &raquo;</TD></TR><TR><TD CLASS="quote">wow, that was scarry. was it OEM bearings? do you think it was cheap oil or was it a long time since last oil change?</TD></TR></TABLE>
it was redline 10-30 and it had about 1500 miles on it so I don't think it was the oil...
Old Feb 16, 2006 | 10:16 AM
AllMTRWH0R3's Avatar
Wow that looks like a few of the engines we had a couple months back. We also found valvespring bits in the oil pan........that was cool looking. Looks like black gold but for mechanics
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revolt_allmotor &raquo;</TD></TR><TR><TD CLASS="quote">
and yes the thread title was plagarized you get ten bonus points if you can tell me where it came from.... </TD></TR></TABLE>
It's the holocaust book........give em my money
Old Feb 21, 2006 | 02:59 PM
Default Re: The Intentional Destruction of Laboriously Engineered Artifacts - A Pictorial (AllMTRWH0R3)
took another pic of the pickup with my new flash, shows the debris inside much clearer:
Sean EH2
15
Feb 11, 2010 10:01 PM
pjr710
Aug 18, 2008 11:18 PM
pkolaboy
Jan 28, 2008 08:51 AM
pkolaboy
Jan 9, 2008 08:50 PM
SiRkid
Oct 23, 2003 02:10 PM
