Can anyone tell for what transmission this ignition switch is for??
its hard to tell from that picture, if there is a square-ish peice on the bottom part of the cylinder with a very small 2 pin connector then that is the key relese solenoid, automatic
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridhonda826 »</TD></TR><TR><TD CLASS="quote">bump, any other thoughts?</TD></TR></TABLE>
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipstar760 »</TD></TR><TR><TD CLASS="quote">ya it looks like a manual... but i cant see the pins</TD></TR></TABLE>
what about this one?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridhonda826 »</TD></TR><TR><TD CLASS="quote">what about this one?
Guest
Posts: n/a
bump
bump
Guest
Posts: n/a
Guest
Posts: n/a
bump 4 you
bump 4 you
Guest
Posts: n/a
Guest
Posts: n/a
does it really matter if it's manual or auto? can't you just take off the side plastic thign w/ the two screws in it and replace it w/ the one from ur m/t?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by plugg’d »</TD></TR><TR><TD CLASS="quote">does it really matter if it's manual or auto? can't you just take off the side plastic thign w/ the two screws in it and replace it w/ the one from ur m/t? </TD></TR></TABLE>
the key switch itself is a different size and that's what I need
