Which EK sideskirts work on an EG Hatch?
For those of you who have fitted EK (stock) sideskirts onto your 92-95 hatch, do you use the sedan, coupe, or hatch version? Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRIUS »</TD></TR><TR><TD CLASS="quote">There is some modding necessary to make them work. Just an FYI if you didn't know.</TD></TR></TABLE>
Yup, I do remember. Thank you for the post though good looking out!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonas99 »</TD></TR><TR><TD CLASS="quote">they're all the same.</TD></TR></TABLE>
even the hatch/coupes? are they diff lengths?
hatches and coupes are the same. They're not like the 92-95 Civics where one is shorter/longer than the other.
I do think that the 4dr 96-00 side skirts may differ a little. If I remember correctly, the rear of th side skirts have a less "curve" than the coupe/hatch, but I'm not 100% sure though.
Sorry to bump this, but I'd rather ask here than make a new thread....[and i've searched]
I have a 95 coupe and I was thinking about doing this too... Exactly how much work is required to get these to fit??
^^ not much .. u first put on the ek from the back and then u see in the front how much u need to cut off.. then u cut.. mold with plastic bonder .. let it sit dry .. repaint a lil in black and ur set..
the amount u need to cut off is about an inch.. mine was about that.
https://honda-tech.com/zerothread?id=142946
^theres a good writeup for it. we put si sideskirts on a my friend 92 hatch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I3ooS710 »</TD></TR><TR><TD CLASS="quote">hatches and coupes are the same. They're not like the 92-95 Civics where one is shorter/longer than the other.
I do think that the 4dr 96-00 side skirts may differ a little. If I remember correctly, the rear of th side skirts have a less "curve" than the coupe/hatch, but I'm not 100% sure though. </TD></TR></TABLE>
He is correct on the differences of the 4dr vs. the hatch/coupe ones.
Stick with the hatch/coupe sides.
Very slight modding is needed.
I just cut the front part of the skirt and used the front mudflap for that clean look.
greyeghatch
30
Jul 2, 2007 08:21 PM
eyesayuh
Dec 6, 2006 12:11 PM
Fuster_Cluck
Jan 16, 2005 12:58 PM
