inline 6 head flange......welding suggestions....
Old Feb 14, 2006 | 07:39 AM
Turbo-charged's Avatar
Default inline 6 head flange......welding suggestions....
obviously im going to bolt thins thing down before welding it....i was just curious if there is a particular way/order to weld this thing in an attempt to reduce warpage.
the flange can not be cut due to the bolt pattern on it
is it best to weld...say the top of all 6 cylinders....then the bottom...then inbetween
or weld 1 complete cylinder...then move on to another cylinder....if so....start in the middle and work out? work from the outside in?
i figure i'll do a little bit at a time to attempt to keep the heat on the flange down.
any suggestions appreciated
Old Feb 14, 2006 | 07:58 AM
IHaveTurbos's Avatar
Joe,
I would do it top, bottom, top, bottom, etc... Let it cool and then go back and weld bottom, top, etc... and do the sides the sameway.
terqui
Aug 12, 2013 03:38 AM
EmminoDaGreat
Welding / Fabrication
Oct 6, 2011 08:15 PM
racerxh00
Oct 14, 2008 06:45 AM
boostedgsr1234
19
Apr 5, 2008 09:07 AM
timmybilt
Oct 1, 2007 11:40 AM
