Will 13'' fit?
Old Feb 14, 2006 | 07:23 AM
Serdar's Avatar
Default Will 13'' fit?
Can 13'' wheels fit crx si's?
Old Feb 14, 2006 | 07:29 AM
I Have an STD's Avatar
wrenchin'
Default Re: Will 13'' fit? (Serdar)
yes
Old Feb 14, 2006 | 07:30 AM
FernEF's Avatar
of course they would.. y wouldnt they
k20rex's Avatar
i have stock '87 prelude rims 13in on my crx. they are stock black with
crome lip
65stang90crx's Avatar
Yes... The stock Steel wheels from the CRX DX (not really DX but it makes it easier) should fit on there fine.
Old Feb 14, 2006 | 07:33 AM
Serdar's Avatar
Default Re: Will 13'' fit? (65stang90crx)
thanks guys i have a crx hf and it looks pretty snug in there and I was wondering if I did a si brake swap how tight the clearance would be.
Old Feb 14, 2006 | 08:05 AM
HxCforever's Avatar
yes they will fit
Old Feb 14, 2006 | 09:00 AM
highrev1987's Avatar
He is talking about the si brakes and 13 inch wheels not just the wheels fitting. you have to take the offset into consideration.
Old Feb 14, 2006 | 09:02 AM
ghost_ryder35's Avatar
Default Re: (highrev1987)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrev1987 &raquo;</TD></TR><TR><TD CLASS="quote">He is talking about the si brakes and 13 inch wheels not just the wheels fitting. you have to take the offset into consideration.</TD></TR></TABLE>
they fit I put them on mine two winters ago
Old Feb 14, 2006 | 09:08 AM
rsca_crx's Avatar
Default Re: (ghost_ryder35)
they will fit, but a spacer might be required depending on the design of the spokes to clear the face of the caliper.
oem 13's fit.
13x8(or 9) is a popular csp autox wheel size.
fwiw- diamond racing wheels in this size DO require a small (3 - 5mm) spacer on 91 si brakes when the pads are new. i have heard that the earlier si design doesn't need a spacer on these wheels, but ymmv.
most other manufacturer's 13's fit without any spacer issues for the caliper, and i have never heard of a 13in wheel whose inner diameter doesnt work with oem crx si brakes.
Old Feb 14, 2006 | 09:47 AM
wrenchin'
Default Re: (rsca_crx)
thats why i said simply, yes, they fit
Old Feb 14, 2006 | 10:50 AM
rsca_crx's Avatar
Default Re: (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD &raquo;</TD></TR><TR><TD CLASS="quote">thats why i said simply, yes, they fit</TD></TR></TABLE>
that's why i responded in a less simple way, because it isn't that simple.
sure they CAN (to answer the op's question as you did, but we can be a bit more productive than that.)
not new science, but here is a current discussion:
https://honda-tech.com/zerothre...96638
Old Feb 14, 2006 | 10:57 AM
AJxr's Avatar
just to chime in i have 13s off an STD on my 90 si, now give me my cookie.
Casey
Classic Hondas
Dec 29, 2008 04:22 AM
coot_er
Jan 13, 2008 08:14 PM
Funkin Flux
Apr 28, 2007 03:50 AM
spunautosports
Nov 2, 2006 06:58 PM
Chugger
Oct 8, 2001 03:36 AM
