Will 13'' fit?
Re: Will 13'' fit? (65stang90crx)
thanks guys i have a crx hf and it looks pretty snug in there and I was wondering if I did a si brake swap how tight the clearance would be.
Re: (highrev1987)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrev1987 »</TD></TR><TR><TD CLASS="quote">He is talking about the si brakes and 13 inch wheels not just the wheels fitting. you have to take the offset into consideration.</TD></TR></TABLE>
they fit I put them on mine two winters ago
1 Post
Re: (ghost_ryder35)
they will fit, but a spacer might be required depending on the design of the spokes to clear the face of the caliper.
oem 13's fit.
13x8(or 9) is a popular csp autox wheel size.
fwiw- diamond racing wheels in this size DO require a small (3 - 5mm) spacer on 91 si brakes when the pads are new. i have heard that the earlier si design doesn't need a spacer on these wheels, but ymmv.
most other manufacturer's 13's fit without any spacer issues for the caliper, and i have never heard of a 13in wheel whose inner diameter doesnt work with oem crx si brakes.
oem 13's fit.
1 Post
Re: (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD »</TD></TR><TR><TD CLASS="quote">thats why i said simply, yes, they fit</TD></TR></TABLE>
that's why i responded in a less simple way, because it isn't that simple.
sure they CAN (to answer the op's question as you did, but we can be a bit more productive than that.)
not new science, but here is a current discussion:
https://honda-tech.com/zerothre...96638
coot_er
01-13-2008 08:14 PM
spunautosports
11-02-2006 06:58 PM
Chugger
10-08-2001 03:36 AM
