Degraded antenna seal + rain = rust?!
Old Feb 14, 2006 | 06:34 AM
run-it-red's Avatar
Default Degraded antenna seal + rain = rust?!
Just noticed that my antenna seal has degraded. The antenna now has a lot of play. I'm thinking that when it rains, water is collecting inside my windscreen pillar (not sure the name?).
Does anyone know if there is a hole at the bottom which may allow water to flow out?
And if it's started rusting, I don't know how I'm gonna get to it to fix it?!
Any advise would be greatly appreciated...
Old Feb 14, 2006 | 12:20 PM
run-it-red's Avatar
Default Re: Degraded antenna seal + rain = rust?! (run-it-red)
man, this board is moving fast!
Old Feb 15, 2006 | 03:47 AM
run-it-red's Avatar
so, what? nobody has any thoughts??!
Old Feb 15, 2006 | 04:26 AM
john666's Avatar
why dont u just seal with silcone or something
Old Feb 15, 2006 | 08:50 AM
run-it-red's Avatar
Default Re: Degraded antenna seal + rain = rust?! (john666)
I intend to buy a new seal.
I was more concerned with how to check and fix any possible rust.
Old Feb 16, 2006 | 08:57 AM
ChadB's Avatar
Just buy a block and the seal comes with it..
https://honda-tech.com/zero...age=1
Let me know if you need one..
Old Feb 16, 2006 | 03:18 PM
run-it-red's Avatar
Default Re: Degraded antenna seal + rain = rust?! (ChadB)
I was considering, but I like my radio too much.
So, no one can tell me:
1) whether I should be worried about any rusting? (If there's a hole, I guess I shouldn't worry.)
2) how I can check/diagnose the extent of any rusting?
3) how to fix?
Old Feb 22, 2006 | 01:28 PM
run-it-red's Avatar
pump!
Old Feb 22, 2006 | 01:54 PM
TurboEM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by run-it-red &raquo;</TD></TR><TR><TD CLASS="quote">I was considering, but I like my radio too much.
3) how to fix?</TD></TR></TABLE>
1) The antenna coming out above the drivers side pillar goes down through the pillar INTO the car and then into the back of the radio. If any water would leak through the seal it would travel down the pillar and go behind your dash/steering wheel area and wet the floor and possibly the wires back there. I dont think there would be any rust but i would get a seal so it doesnt short out any wires.
2) Get a new seal and you should be fine. I don think youll get rust.
3) Get a new seal.
Old Feb 23, 2006 | 03:32 AM
run-it-red's Avatar
Default Re: Degraded antenna seal + rain = rust?! (TurboEM1)
Much appreciated.
Will14
Mar 21, 2011 12:42 AM
mrader
Oct 27, 2009 03:42 PM
awdgsx96
Oct 30, 2007 02:39 AM
shoebox
14
Sep 7, 2006 08:14 PM
S2000Forsale
Honda S2000
Jul 11, 2006 01:00 PM
