After headgaket, and h20 pump, the car still overheats
Old Feb 14, 2006 | 04:51 AM
naptownrex's Avatar
Default After headgaket, and h20 pump, the car still overheats
Basically, I put the headgasket on backwards by accident and i start the car up, and i dump a gallon of oil on my garage floor. so i tear the head off the bottom end, turn the head gasket around, and then throw it all back together. It starts, and runs ok, but has a very high idle. I take it out for a spin, and after a few minutes, it starts to overheat. it starts to overheat QUICKLY. once that temp gauge started going up, it went up quick. so i checked the coolant after i got back, and it seemed that i was a little low, but i was full when i left. i just figured that it was used to fill up the water jackets. or that it was burning. so, any ideas as to why im overheating? I emptied my coolant, but there was no sign of oil in it.
Old Feb 14, 2006 | 06:27 AM
Black4thgenEF's Avatar
Default Re: After headgaket, and h20 pump, the car still overheats (naptownrex)
Did you loosen the bleeder screw when filling the coolant? Air in the system can be a bitch.
Old Feb 15, 2006 | 04:23 AM
naptownrex's Avatar
Default Re: After headgaket, and h20 pump, the car still overheats (Black4thgenEF)
I guess thats possible, i didn't lossen the screw. is there any way that I was suppost fill the h2o jackets or anything? Ill try filling it back up, by releasing the bleeder screw for the first little bit of coolant. any more ideas?
Old Feb 15, 2006 | 06:03 AM
naptownrex's Avatar
uh, one mor question- where is the bleeder screw? Is it located near the thermostat?
Old Feb 15, 2006 | 07:11 AM
mike-y's Avatar
if your motor has it, it may be located near where the top radiator hose connects to the block.
If you can't find it there, you can try this: jack up the front of the car a little bit, you don't need to get the tires off the ground, but just get the front of the car pointed up from level. then top off your radiator, leave the cap off, and start the motor and let it idle. Keep topping off the radiator as needed (air will be bubbling out). when there is no more bubbles, let the car idle for a few more minutes (or until the fan kicks on) then shut it down and replace the cap. check the overflow, and you should be good to go. Make sure you watch the temp guage while you are doing this tho!
If you are still overheating, you should probably have the thermostat checked.
Old Feb 15, 2006 | 08:09 AM
hb_guy's Avatar
Default Re: After headgaket, and h20 pump, the car still overheats (mike-y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike-y &raquo;</TD></TR><TR><TD CLASS="quote">if your motor has it, it may be located near where the top radiator hose connects to the block.
If you are still overheating, you should probably have the thermostat checked. </TD></TR></TABLE>
i agree with him 100%, also, just change the thermostat. its only 9 bucks might save you money on advil
Old Feb 15, 2006 | 03:20 PM
naptownrex's Avatar
Default Re: After headgaket, and h20 pump, the car still overheats (hb_guy)
thanks guys, ill give it a shot. you mean the upper radiator hose, right? btw, i replaced my thermostat less than a month ago, so it should be ok.
Old Feb 15, 2006 | 05:33 PM
naptownrex's Avatar
just checked my thermostat- it works. im flow testing my radiator- should have it back tomorrow
b18egtheehatch
Feb 17, 2015 08:12 AM
Bendito
16
May 7, 2012 09:40 AM
Volkspeed
Oct 5, 2008 06:06 PM
justseeingifitistaken
Jan 10, 2007 08:26 AM
superstock2
Aug 15, 2006 06:04 PM
