brakes loosing pressure when making a tight turn... master cylinder problem? or brake booster
Old Feb 14, 2006 | 02:43 AM
LsVTEC 510's Avatar
Default brakes loosing pressure when making a tight turn... master cylinder problem? or brake booster
this just started to happend right after i had changed my brake pads..
everything went smooth as it should. i bleed the brake lines and etc.
now when i make a sharp turn or a U-turn, i tend to loose pressure when hitting the brakes afterwards. when im driving and braking, its fine. pressure seems to be good. I even flushed the fluid again, and this still occured. could there possibly be a leak somewhere in my brake booster? or is this a symtom of my master cylinder going bad. this only happens when i dont brake while i make a sharp turn or a u-turn at the same time (braking after turning a bit, then loosing pressure)
Old Feb 14, 2006 | 06:57 AM
old man neri's Avatar
Default Re: brakes loosing pressure when making a tight turn... master cylinder problem? or brake booster (L
You didn't accidentally run a break line incorrectly around a suspension component or something when you were putting everything back did you? Just a quick thing to check, maybe something is getting kinked when turning. Just a thought.
Cheers and good luck.
Old Feb 14, 2006 | 11:02 AM
LsVTEC 510's Avatar
yeah im pretty sure i did everything rigth, but ill double check that... sounds like that could be the problem
dcmatt
Suspension & Brakes
Sep 22, 2013 07:37 AM
eg_92vxhb
Jan 8, 2003 02:58 PM
CD8
Jun 18, 2002 09:30 AM
acuraLSSE95
Jan 23, 2002 09:21 AM
Rboosted717
Aug 1, 2001 12:14 PM
